		Omega Help Area => Omega General Help => Topic started by: raywilb on 23 August 2016, 20:04:07
				I had the sump & oil pan off recently & since putting it back together a low warning has appeared. the electric is attached ok. I hope it not the sensor that is inside the oil-pan. it is not low either.
				Is it near halfway between min and max - that'll bring it on on a cruise.
Failing that, check the sensor is plugged in.
