Omega Help Area => Omega General Help => Topic started by: Chief972 on 04 September 2016, 19:18:54
Title: Pool of water
Post by: Chief972 on 04 September 2016, 19:18:54
Hi I noticed a pool of water under the passenger side front today and managed to trace it to a pool of water a few inches deep just under the pollen filter housing, my coolant is fine I think maybe it will be rain water is this correct or am I missing something. Thanks.
Title: Re: Pool of water
Post by: gbh on 04 September 2016, 19:21:08
There is a drain there which sounds like it might be blocked!!!
Post by: Nick W on 04 September 2016, 19:40:36
Did you have the A/C on?
Post by: Doctor Gollum on 04 September 2016, 19:51:11
Deffo blocked drain, work back along the chassis rail until you reach the bottom of the bulkhead. Drain is just above...  :y
Post by: Andy B on 04 September 2016, 23:46:37
As above, the drain is blocked. Roll up your sleeve &  get your arm in there & have a poke about ( ::)) ... your arm wil go in there ... just a little more difficult getting it out.
http://www.omegaowners.com/forum/index.php?topic=90582.0
http://www.omegaowners.com/forum/index.php?topic=90535.0
Post by: Magwheels on 06 September 2016, 18:34:31
Give it a poke with a bamboo cane then the pressure of the water should help clear it.
