Chat Area => General Car Chat => Topic started by: JamesV6CDX on 08 September 2016, 23:23:43
Title: 2008 VW Passat TDi
Post by: JamesV6CDX on 08 September 2016, 23:23:43
I've the opportunity to purchase a 2008 Passat Estate TDi. One owner. Full MOT, immaculate in and out, but 200k miles, for £1400. 6 speed manual.
What's wrong with it?
It's gutless. Little if no turbo assistance.
I'm assured -
No smoke or knocks. Good gearbox and clutch. No warning light.
Worth a punt? I'm considering it for my uncle rather than me, as I may have something new coming quite soon :y
Title: Re: 2008 VW Passat TDi
Post by: JamesV6CDX on 08 September 2016, 23:26:52
I don't mind playing with Diags and owing v small jobs like hoses, but worth noting I'm not able to do anything remotely heavy or strenuous. Although I guess we have Serek for that! :y
Post by: tidla on 08 September 2016, 23:39:04
Bit weird if the turbos not working and theres no black smoke on boot down?
Ive had a broken as in snapped tubo shaft and stuck veins on these.
Post by: JamesV6CDX on 08 September 2016, 23:55:32
The lack of smoke points to an electronic boost control issue to me?
Post by: Doctor Gollum on 09 September 2016, 02:28:58
Cam and follower wear most likely... Budget for a top end rebuild and sell it :y
Expensive IMHO.
Post by: JamesV6CDX on 09 September 2016, 03:26:27
Expensive IMHO.
Thanks mate :y
Post by: JamesV6CDX on 09 September 2016, 03:28:24
Just to add... I won't be doing that. I was hoping to source it as a nice surprise for a relative, but as my physical capabilities probably stop at changing a sensor at present, I won't be game for top end work :y
Post by: henryd on 09 September 2016, 09:47:06
As a first step try and drive it with the maf disconnected,if its faulty they'll often run better without it connected
Post by: TD on 09 September 2016, 18:56:00
The Fiat Skudo I had, the shaft snap in the turbo, didn't smoke with the 'go faster' pedal on the floor....it was also gutless, without the turbo working.....so imo could be the turbo. If it is the turbo....I would say don't buy it....the turbo in the skudo died because of oil starvation (the oil strainer was blocked with crud) .... the engine after the turbo was replaced....died a death a few thousand miles later, probably because of crud in the oil ways  :-\
Mr DTM made a comment to me, that if the turbo has died the engine wont be far behind! Unfortunately for me, he made that comment after my engine had died...
Post by: Nick W on 09 September 2016, 20:42:22
Now you know why a an 8 year-old £30k car is 'worth' £1400. Which is a maximum of £1000 if they've had some quotes to fix it.
Cheap, used diesels are hard to justify buying if they're working OK. Ones with existing faults are scrap.
Post by: serek on 09 September 2016, 21:11:50
I'm assured -
tbh mint Passat with this miles on clock its worth about £1k as is
give me ring tomorrow we have chat about it
