Chat Area => General Discussion Area => Topic started by: Gaffers on 10 October 2016, 18:31:20
Title: another one for the builders
Post by: Gaffers on 10 October 2016, 18:31:20
I have a wall between the kitchen living room which has swing doors fitted.  I hate them.  I want to replace them with pocket doors.  The wall in question is plasterboard with stud and joist but i am not sure whether it is load bearing or not which would put a debbie downer on the idea.  The wall in question does butt up to the u-shaped stairs, in fact they go over part of the wall in to the living room which further makes me suspicious.
Apart from ripping off the plasterboard and having a peek is there anyway i can find out if the wall is load bearing or not?
Title: Re: another one for the builders
Post by: redelitev6 on 10 October 2016, 18:41:58
what size stud is it ? unless it's something a really big size I would think it very unlikely to be load bearing
Post by: biggriffin on 10 October 2016, 19:03:58
If the roof/ floor joist run parallel, then not load, if they run across more than likely load.
Ps I'm not a structural engineer.
Post by: powerslinky on 10 October 2016, 19:12:38
Timber frame houses do  have load bearing internal walls  . .. made of  . .you've guessed it  . . .wood ;)
When i have worked on these  & it is a long time ago (1980's)  the whole house , doors, windows, roof as well was all put up before the brickies put a single skin of brickwork around it.
Just be aware there could be load bearing timber walls if built to that design.
And along BG I'm not a structural engineer either  ::)
Post by: STEMO on 10 October 2016, 19:25:17
Be handy if there was a structural engineer.
Post by: Shackeng on 10 October 2016, 19:41:00
If you can access a light fitting nearby you should be able to check this. :y
Post by: STEMO on 10 October 2016, 20:07:18
I really, really, really would pay a structural engineer to tell me definitively, before I demolished messed about with my home.
Post by: Sir Tigger KC on 10 October 2016, 20:29:43
Oh c'mon, what could possibly go wrong?  ::)
Post by: Gaffers on 10 October 2016, 21:25:19
Thats a good suggestion  :y
Post by: Gaffers on 10 October 2016, 21:29:11
True, and thats what i will probably have to do anyway to satisfy my insurance but i would rather do it in a position of knowledge rather than ignorance.  This is why i like this forum, someone usually knows the answer :y
Post by: Lazydocker on 10 October 2016, 22:57:49
Just knock it down :-X ::) :D
Post by: tigers_gonads on 10 October 2016, 23:43:27
How old is the property Matt ?
Post by: Gaffers on 11 October 2016, 07:44:19
3 years old which is why i suspect that all or part of the wall is load bearing.
Post by: biggriffin on 11 October 2016, 08:26:51
It's insured. Just do it ;D
Post by: Marks DTM Calib on 11 October 2016, 08:39:19
Not seen internal timber load bearing walls for decades.
Do you know what the construction type of the walls around the stairs are as these are often load bearing on two sides and will give you a big pointer as the house construction type.
Its worth popping out light switches and sockets to see what sort of material is used in the construction at various points.
Other easy check is to make small holes above the door to see what is in place (they are easily filled), if its a single timber its not going to be load bearing, if its a sodding great big, steel or concrete lintel (as timber wont support the floor load for a two door span) then it is load bearing.
Post by: Gaffers on 11 October 2016, 13:14:58
The stairs are U-shaped with the lower section built on a base.  The long section is against the supporting wall and sits on the base.  The 3rd and last section is the part I am not sure about as it partly straddles the wall in question.
Here is a drawing from the paperwork, seems to suggest non-load bearing.  The wall in question is boxed in red.
(http://i287.photobucket.com/albums/ll138/mrgaffney/House_zpsasvedfxe.jpg)
And plans for the stairs, which I cannot figure out....:
(http://i287.photobucket.com/albums/ll138/mrgaffney/House2_zpsvbcx2w73.jpg)
Post by: Marks DTM Calib on 11 October 2016, 13:27:40
I would agree at non load bearing, the floor joists in this case will run left to right and pickup on a load bearing walls either side of the house.
Just stick a few holes above the door in question with a small screwdriver and check for the presence of wood only.
Post by: Gaffers on 12 October 2016, 08:35:36
Thanks, shall do :y
Would a joist/metal detector do or should I physically check.
Post by: Marks DTM Calib on 12 October 2016, 08:58:27
I would check, even a screwdriver of say 4mm diameter will allow you to prod and determine what's behind the plaster work and any holes are easily filled being so small.
Post by: Gaffers on 12 October 2016, 09:18:58
thanks again :y
Post by: Mr Gav on 12 October 2016, 12:57:30
It may be partially load bearing as most modern houses don`t have internal block walls anymore, and it`s unlikely to have any steel work as this is also uncommon in modern housing due to costs.
The only sure way to tell is if you could get a hold of the drawings for the floor joists, other than that you can see which way the joists run, if they`re parallel with your wall then you should be fine but I`d make sure that both kitchen and living room joist run parallel with the wall.
Post by: STEMO on 12 October 2016, 13:32:20
Ermmm....no, Gav. There's another way to find out for sure.  ;D
Post by: Marks DTM Calib on 12 October 2016, 13:36:02
Its not load bearing, absolutely clear from the drawings and dead easy to check.
Internally they use concrete for load bearing walls up to circa 1.5m then its steel (as a concrete lintel gets a bit deep above that sort of span)
Post by: Mr Gav on 12 October 2016, 14:35:51
Thats what happens when you don`t read the post in it`s entirety  ;D
Never saw the bit with the drawings on lol
Post by: Mr Gav on 12 October 2016, 14:42:33
You wouldn`t find one of those on a stud wall though would you?
Post by: Marks DTM Calib on 12 October 2016, 15:25:02
You wont find a load bearing stud wall with a double door in though  :y
Post by: Gaffers on 12 October 2016, 16:31:37
Yeah, erm you're never working on my house.....ever  ;D ;D
Post by: Mr Gav on 12 October 2016, 19:34:51
Too far for me anyway  :P ;D
