Omega Help Area => Omega Electrical and Audio Help => Topic started by: Andy A on 22 October 2016, 14:11:02
The battery that is in the car is a 60Ah 550CCA.
Will I run into any problems with the alternator etc if I put in a Bosch S5007 100 Type 74Ah 750CCA battery?
Thanks
It will be fine.
Is this the correct battery size 278 long x 175 wide x 175 high?
Will this size fit OK as well 278 long x 175 wide x 190 high?
I have a choice of the 2 batteries below for the same price.
Varta 096 (E44)
Varta Silver 780CCA Battery
Part Number: 096 (57700)
Short Code: E44
Capacity (c20): 77Ah
CCA (EN): 780A
Dimensions (mm): 278 long x 175 wide x 190 high
Varta 100 (E38)
Varta Silver 750CCA Battery
Part Number: 100 (57402)
Short Code: E38
Capacity (c20): 74Ah
CCA (EN): 750A
Dimensions (mm): 278 long x 175 wide x 175 high
Thanks
278 long x 175 wide x 175 high :y, dont go any higher than 175.
Just ordered a
Varta 100 (E38)
Short Code: E38
CCA (EN): 750A
Thanks :y
