Chat Area => General Car Chat => Topic started by: Webby the Bear on 02 November 2016, 19:53:51
Title: Is it not possible....
Post by: Webby the Bear on 02 November 2016, 19:53:51
.....to measure the power output of a automatic omega?
I understand from here that dyno isn't possible for autos. so is there any other way?
Title: Re: Is it not possible....
Post by: STEMO on 02 November 2016, 20:01:01
Nobody answer him..........please  :o
Post by: Webby the Bear on 02 November 2016, 20:08:57
i promise I wont go full 0-60 on ya  :o
just curious.
Post by: Migv6 le Frog Fan on 02 November 2016, 20:13:58
 ;D ;D ;D
Post by: flyer 0712 on 02 November 2016, 20:16:43
ok then i will answer him......aint got a clue  ;D ;D
Post by: Nick W on 02 November 2016, 20:19:19
How do you think Americans do dyno runs, when approx 97.85639360% of their cars are automatics?
Post by: Webby the Bear on 02 November 2016, 20:22:18
right, so it is possible? lol
Post by: andyc on 02 November 2016, 22:29:57
Take the motor out and mount it on an engine dyno :y
Post by: biggriffin on 03 November 2016, 06:29:07
Don't give him idea's  ;D
I believe that its run up on the roller's, then the tech2 is used to lock the torque converter, or something like that.
Post by: citroenguy on 03 November 2016, 09:08:15
My brother put his 9-5 auto on the dyno, so it seems likely that an Omega could do it too.
OT it has 292 whp  ::) 8)
Post by: Diamond Black Geezer on 03 November 2016, 09:11:59
So I've read, people have had their autos are dyno'd but the gearbox 'kept changing down' which doesnt make a whole lot of sense, as you can lock the box into 1st, but not really sure how dynos work. As I understood it, you rev it, then let the revs die off, the resultant 'drag' is used to calculate a figure (bhp / hp being a mathematical figure, it's not 'real' in the same way a second is, it's not like lb/ft or 14.5 Newtons etc) HOw, however, that relates when you use an auto, as you say, the TC is a completely different kettle of fish.
That's my knowledge of this pretty much exhausted.  :D
Post by: Marks DTM Calib on 03 November 2016, 10:10:53
There is something in TIS, you can use  Tech2 to lock the torque converter.
Post by: Diamond Black Geezer on 03 November 2016, 10:29:46
So we need someone with a Tech2 to turn up on a pre-arranged Dyno day, then  :)
Post by: tigers_gonads on 03 November 2016, 11:46:42
Somebody ban this man .................. NOW  :D :D
Post by: Diamond Black Geezer on 03 November 2016, 11:49:04
 :D Oh, come on, admit it, you want to know if your motor manages to push out over 100bhp, or not!  :D
Post by: tigers_gonads on 03 November 2016, 11:52:22
Oi tosser, my car has a proper gearbox so no need for any tech 2ing on mine  :P :P ;D
And giving the way it came back from Skegness last Friday evening, i'd say its got pretty much the full 218 horses  ;)
Just realised something  :(
PM incoming J
Post by: Field Marshal Dr. Opti on 03 November 2016, 12:11:22
just curious.
I would be interested to hear about this. :)
Post by: EMD on 03 November 2016, 12:24:33
just curious.
(http://forums.macresource.com/smileys/slap.gif)
Post by: Webby the Bear on 03 November 2016, 18:31:30
Haha tossers!
As said I'm not getting in to this. However. Does anyone know of a place that can do this?
Post by: aaronjb on 04 November 2016, 11:40:45
DBG, the reason 1st gear isn't used is that you want as close to a 1:1 gear ratio as possible to eliminate the mechanical torque advantage of gearing.. easy in a manual, whack it in 4th gear and go. Bit of a problem with a slushbox though.
Webby, go to Northampton Motorsport. They won't have a tech2 but they are knowledgeable guys..
Post by: Diamond Black Geezer on 04 November 2016, 11:50:01
Ahhh, thanks! that makes senses (and thereby makes it obvious why theres a tech2 means of locking the TC)  :y
Post by: Webby the Bear on 06 November 2016, 12:29:59
Thanks Aaron. Much appreciated  :y
Post by: biggriffin on 07 November 2016, 07:17:47
How does DBG survive on twitter , as your limited to 140 character's.
Post by: Diamond Black Geezer on 07 November 2016, 09:52:12
I don't use it  :D
