Chat Area => General Discussion Area => Topic started by: TD on 16 December 2016, 19:40:52
Quite pleased with myself today :)
My mum has been in hospital for the last 3 weeks.....today she was going home :y
Ive had her central heating set at 15C for last 3 weeks.....just to stop the house getting too cold...and just let it do its thing..
So this morning I pop over to her house and turn the stat up to 21C....boiler kicks in, but 5 mins later it shuts down again and stays off....rads were luke warm when the boiler shut down...
I knew she paid for central heating insurance.....so I phoned up insurance comp....and got told to phone the number they gave me and quote an authorization code.....so phoned the central heating comp and explained the situation....got told they couldn't do anything for a week >:(
Phoned the insurance comp back, told them the outcome of that call.....and was given another number to call.....same result basically....carnt come out this week or next >:(
So I thought, sod em, lets do some basic fault finding....
So...
Boiler kicks in....but shuts down super quick....
Went up into loft to check the pump.....pump is running....but found two bleed valves about 2 inches above the pump (why 2valves I don't know)
Opened one valve, air hissed out.....closed when water ran out
Same thing with the other valve.....air hissed out then water.....
Boiler kicked back in and heating was working again :y
So guess the pump was trying to circulate air!
Lovely and jubley warm when she came home :y
I think I'm going to cancel the heating insurance she has......as clearly it doesn't suit an 85 old....I stressed this when I rang ins comp....and all they did was give me numbers to plumbers...whatever....who wouldn't come out as an emergency! >:(
Its £300 a year she pays for central heating failure >:(
I think I'd be inclined to do the same & cancel. If they can't manage to get some one out to your Mum while the weather is genaerally mild, how long would they have expected Mum to wait if the weather had been freezing? The premium would go a long way to paying a plumber if the need arose.
Well done on your diagnostic skills ;) ;)
Well done, Dave, award yourself a blue peter badge. A lot of these 'insurance' companies are merely 'go-betweens', who just hand out phone numbers and, no doubt, pay the plumber next to nothing for the job.
I often wonder whether I'll be top of the list if I ever phone the RAC and say I'm covered by my bank account. Or if paying customers will get seen to first.
£300 :(
A part of that would be better spent on getting an old school family plumbing/heating company to do an annual service. Keep the rest for a rainy day.
Ours has been used 4 times over a few years, each time sub 30 minute response, best one I hadnt finished posting on facebook I was stranded before the van pulled up behind me! was instant! Dont think youve anything to worry about.
Good result on the heating Dave, Save her eating all your pickled eggs to keep warm ;)
Definitely cancel it, if you are unable to sort it yourself get someone to recommend a local chap who is reliable,far better than £300 pa for sweet fa.
Funnily enough Steve, I've had to call them twice in the last two years (I'm through my bank) and both worked OK, although the recent non-starting incident took nearly three hours to arrive. However I suspect that was my own fault for telling them I was waiting in the golf club bar! :y
That's good to know Jimbob and Chris :y It's the wife I worry about, if she ever needed to call them out to change a tyre.
Every RAC job I went to had been waiting for hours longer than we had the job. So don't worry, you'll receive the same terrible service as their paying customers. You have checked that your 'free' cover is actually worth more than you paid for it?
My last experience of the RAC was called them on a cold early evening (about 5ish), they turned up about 11. Tosspots.
Yep, £10.50 a month, both covered for roadside assistance, home start and onward travel with either courtesy car or hotel stay if no repair possible.
We have central heating insurance with British Gas.Not sure of cost but around the £300 mark per year.Annual service and emergency call outs parts and labour included.Never had a problem with them always been prompt and efficient.Just called them as 3-way valve stuck here within 2 days new valve and new pump fitted and boiler serviced in all excellent service would thoroughly recommend them if you want peace of mind for your Mum
Was over at mums today.....even tho heating was working....I heard some gurgling noises from the heating....went into loft and got some more air out of the vent valves.
So, what ive decided to do.....seeing as when you bleed a rad, black water comes out.....
Cancel the ins she has....as it seems its useless for her.
Hope the system keeps working over the winter...
Then when its warmer.....get the plumber I use to come out...
Give the boiler a service (which to be fair the ins comp did every year)....and also give the system a power flush to get of the sludge it obviously has in it....
Tho this might be brought forward, if the system becomes more problematic :y
Yep, sounds as though the system is generating a lot of hydrogen due to corrosion. :y
Sounds very similar to what's been happening with mine. ::) :(
British gas are the worst of the worse when it comes to heating systems, over priced and to many of them lacking competence.
As an example to the post about the mid position valve and pump replacement, a reasonable plumber would fit a new Grundfos pump, Honeywell valve (although it was probably only the synchron motor that had gone. but its only worth fitting Honeywell as they last) and a service for the £300 a year charge :y
My advice to anybody would be, if you really want piece of mind, pay the £30 a month into a savings account and use it for the maintenance costs.
TD, my concern with your mothers heating system is that BG should have been testing the water in the system to ensure the corrosion inhibitors are still ok as part of the service...........clearly they are not (might be worth doing a pop test with the gas from the bleed valves)
Grundfoss & Honeywell - a winning combination
Had my Honeywell valve for nearly thirty years, new boiler and Grundfoss pump ten years ago and still going strong.
I have fitted many valves to various piece of equipment over the years and would still rate Honeywell as the best option in a domestic heating system
The shame is that BG usually use an own branded valve which are utter rubbish (Drayton tat)
Ah, boiler insurance.. I decided to take that out on the house in Bracknell now it's rented out, to save any big headaches.. (It's "landlords insurance", of course)
The new tenants have a problem with the boiler (losing pressure, again) so the insurance people are called, they send a plumber out who .. removes a part for replacement, takes it with him and says he'll be back in a fortnight, leaving them with no heating!
What ground my gears was a) why do you need to take a part with you to get a replacement, even I can find the parts listings online.. b) why leave them with no heating when what they had was heating that needed topping up every week or so..
'course being the landlord I'm on the hook for alternative heating etc etc.
So .. Homeserve. Best avoided. Which I should have known, really...
BG don't come out to service my mums boiler. The heating insurance is with an insurance company, which I carnt remember the name of now.... You phone them when you want it serviced (once a year) . They give you a heating/plumbing companies number and you have to phone them and make the appointment. Who the company is can be anyone, but certainly isn't BG and certainly not local either, given the area codes I was dialling when I attempted to get an emergency visit, before giving up and sorting it myself.
I'm actually tempted to ask the plumber I use, to write me out a bill for 'fixing' my mums heating....and send that to the insurance company, as the two numbers they gave me wouldn't come out for an emergency visit. I class fixing the heating system of an 85 yo as an emergency in winter. Altho its not that cold at the moment, she has to have the heating on all day. Usually the room stat is set around the 25C mark when I visit.
I agree, its certainly worth a letter, requesting payment, in a measured way, together with the plumber's bill, and preferably a atatement from someone independent (GP?), describing your mum's requirements due to age. Citizen's Advice may help, and would be worth contacting, also Age Concern for advice. :y
I've got to have a look my mums policy to see if it included emergency cover.....if not, probably not worth pursuing it, tbh...
But I have been playing on Saga website on home buildings/contents cover....
For about the same price my mum was paying the other insurance company....she can have full building/contents cover that includes all electrics failure/central heating failure with emergency cover.....
I think that maybe worth investigating further :y
:y :y :y
