		Chat Area => General Discussion Area => Topic started by: grifter on 14 March 2017, 22:03:04
				Some interesting stuff in it like to reduce handbrake snatch you are advised to drive the car back and forward while gently applying handbrake to clean the shoes as they do not get used in normal service braking, which I have done anyway. Also noticed they advise to connect and disconnect Earth lead on a battery first or connect up to that first with leads. WTF? Earth first I would have thought - no?
 Oh and one other piece of advice: be courteous when closing doors at night as slamming doors is noisy (good for that neighbour you hate then!)
 I'll also need to read the part about operating the facelift heater about another 20 times to try and work it out!
				I'll bet it's riveting. Are you married or do you live alone, in a hut, far from civilisation?  ;D
 Lol bedtime reading, I think it spawned from trying to work out the heater controls then I thought what they hey read the whole thing!
 A bothy perhaps?
 A bothy perhaps?
 Are you going to vote for independence, Jock?  ;D
 A bothy perhaps?
 Yeah if I can get my ginger ass out of my bothy to the voting booth lol!
 A bothy perhaps?
 I meant the Jock who lives in Teesside in Southern Scotland.
				Lord Opti can recite the Omega manual, word for word, off by heart, along with most laptop repair manuals. 8) 8) 8)
 He also knows all the important Omega part numbers along with the part number for any laptop screen that you care to mention. ::) :-X ;D
 M         -          A          -        N        -       U           -         A            -         L
 Sorry. But what's that ?
 A misspelled Spanish Man's name!
 I thought is was associated with 'distructions', where it tells you what you should have done afterwards! :-X
				I've read the blasted thing till I'm blue in the face, and I still can't work the heating system properly !!! :-[
				Ditto .but then mine does need a matrix flush !
 Here do ;D
 Leave in Auto with all the vents open. Adjust temperature to suit. If you need to clear the screen, close the dash vents and press the front screen button.
 Never press the ECO button.
 Here do ;D
 That's about it.
				Guide in the test section :y
				Sorry Al, I have to ask the question. Just read it to swmbo, soon as I said 'Never press the Eco button' , she nearly wet herself laughing !!!! Thats all we ever seem to press :-[ :-[
 The question obviously is....why ???
 Here do ;D
 That's about it.
 That's the whole point of climate control. Mine's set to 20degrees, and when the external temperature is between about 10 and 20 I usually just turn it off.
 The new heater matrix I have on the bench would be better if I fitted it to the car though ::)
 Eco on the display means that the airconditioning is switched off, rendering the entire system useless ;)
 Errr no, you connect the negative last and remove it first for safety reasons mainly.
 If you disconnect the Positive first or fit it last then there is the potential for the spanner or socket being used to come into contact with a metallic part, which be default will at negative terminal potential.......
				Yes, I've read it cover to cover. Before I bought one.
 So, to be quite clear about this....if I use my starter pack, I should connect to the positive terminal first, then connect to an earthing point. Been doing it the other way round, as, if I remember correctly, doing it your way, creates loads of sparks !!!! ???
				Not sure if Ive ever read it cover to cover tbh. I have read the Bible cover to cover, more than once though. It didn't make me a good person I'm afraid.  ;D
 A bothy perhaps?
 Ahem. Western Denmark.
 An old mechanic once told me to relate it like going to a party - arriving at the party (connecting the battery) you want positive people arriving first before negative people.
 Leaving the party (disconnecting), you want negative people leaving first before positive people.
 Very simple, but an easy way to ensure the correct connection and disconnection of the terminals  :y
				This is all for -ve earth cars.  Other way round for (the now rare) +ve earth cars.
 Ignoring the scathing comments from Mr DTM about earth :P
 There will always be some arcing when connecting a power supply (e.g. your starting pack) to a battery which has reduced voltage on it. In fact there will only be no arc if the two battery voltages and internal resistance are the same.....not much chance of that being the case.
 The basis behind jump or boost starting and connecting the negative lead last to a major metallic object on the engine (e.g. the lifting eye) is so the arc is not near the battery......where there could be hydrogen present due to the state of the discharged battery..............and I have seen one blow up! (found it very amusing!)
 Of course a vehicle does not have an earth (well it might do if you connect it via a large cable to a big earth spike which is hammered into the ground), it does have a ground/chassis connection or negative (or positive if stupidly old).
 :y :y
 The basis behind jump or boost starting and connecting the negative lead last to a major metallic object on the engine (e.g. the lifting eye) is so the arc is not near the battery......where there could be hydrogen present due to the state of the discharged battery..............and I have seen one blow up! (found it very amusing!)  ....
 Can I do it the other way then on my Merc?  ::)
 In my youth, working on a car of long ago, I did that............very interesting sparks, heat, and slight welding was the result!! :o :o :o ;D ;D ;D
 Indeed Negative must always come off first, unless it is a positively earthed car. :y
				 ...., unless it is a positively earthed car. :y
 You'll start Mark off again ....  ::)
				I once saw a "maintenance engineer" connect a 24v truck jumpstart pack to a 12v battery. The explosion was like a shotgun going off. It left me with ringing ears. Bits of the battery were found on the roof of the factory. The bloke who did it, somehow got away without so much as a scratch.  ::) ;D
				A colleague asked to borrow my jump leads where his car battery was flat. When he returned the leads the insulation on them was a bit melted and the worse for wear, where he admitted the nearest convenient charged battery was a 24v one on an adjacent lorry. :o :o :o
 Here do ;D
 It's an ejector seat!
 I have a new unused screen. It cost about £35, I suppose I should sell it  on ebay. I bought the bitch a new computer instead. Seven hundred and something quid.
 Too kind for my own good. :)
 That`s one way & here`s mine
 RED to dead
 BLACK goes back   :y
 Blimey Mrs Opti likes an expensive frizbee M'lud!  :o  ;D
 Do they fly any better?  :-\  ::)  :)
 Of course they do, they fly first class! :o :o ;D ;D
 That just doesn't make sense to me. Why would you leave car electrical system at positive potential?
				Do it your way and touch the spanner to the wing/slam panel as you undo the positive and report back :y
 It's not at any potential because you've broken the circuit. Without the negative terminal attached, there is no path back to the battery.
