Omega Help Area => Omega General Help => Topic started by: Fabianknutsen on 22 March 2017, 16:39:58
Title: High idle just after start
Post by: Fabianknutsen on 22 March 2017, 16:39:58
I have a Omega B1 2.5 v6, and i  was wondering if its normal that the idle is quite high just after startup ? After some minutes it goes back to approximatly 700-800 rpm.
Title: Re: High idle just after start
Post by: MonzaGSE on 22 March 2017, 17:33:11
My 3,0 will idle at around 1100rpm when cold. In the winter for a couple of minutes. Shorter in the summer. After that it will drop straight down to 500 rpm. I believe thats normal behaviour.
Post by: Doctor Gollum on 22 March 2017, 19:01:37
Totally normal, especially if it's properly cold outside...
Certainly on the 2.6/3.2, the ecu will adjust fuelling a varying amount according to temperature. All to do with getting the cats upto temp asap :y
Post by: cam.in.head on 22 March 2017, 19:09:50
Yep totally normal .the 2.5 and 3.0 have an idle air valve on the side of the plenum .this lets in air when engine is cold and closes as engine warms.it also keeps the speed stable as more electrical items are turned on.the later 2.6 and 3.2 don't have this valve and do it electronically instead
Post by: TheBoy on 22 March 2017, 19:17:31
That is too high, a 2.5/3.0 should idle at a shade under 500 rpm (AC off), or about 550rpm (AC on).
Check some retard hasn't adjusted the throttles to stop them fully closing.
Post by: cam.in.head on 22 March 2017, 22:02:27
Or that the idle unit hasn't slipped out of its rubber mounting causing an air leak
Post by: frostbite on 28 March 2017, 19:44:11
Is the multiram operational?
should be growling for a couple of minutes then settle
Post by: TheBoy on 29 March 2017, 14:27:28
Eh?
Post by: Bojan on 29 March 2017, 14:35:47
Growl is from SAI pump.
