Omega Help Area => Omega General Help => Topic started by: karlinz on 14 April 2017, 00:47:44
Title: coolant tank
Post by: karlinz on 14 April 2017, 00:47:44
Hi All.
developed a split in the coolant expansion tank on my omega a 12 valve,need to get a new one,but cant find one any where,seems too be every make except omega.getting it welded but may not be successful so would like a new one as a spare, Got one on loan off Senator B  its the same.etc.Any one know where i can get one from? any help appreciated. Thank you.
Title: Re: coolant tank
Post by: Keith ABS on 14 April 2017, 07:37:34
  is the tank the square shaped one or the ovel shape tank?
Keith ABS
Post by: karlinz on 14 April 2017, 20:58:32
Thank you for the replys,its the square shaped one.outlet on bottom right two inlets or outlet?top rh corner,and has a sensor cap with a small float on it.i am using a loan one at moment off a Senator B, the GM number on them is 90 325 543 it made wonder if another GM bottle would do if all inlets outlets, and cap fitting were the same roughly,i could make it fit,dont know how critical it is too have the correct one.?Thanks.
Post by: GastronomicKleptomaniac on 15 April 2017, 21:33:02
Perfect time to get an aftermarket, shiny metal replacement, from a kit car maker, rally car supplier or similar... :y
Post by: karlinz on 25 April 2017, 22:15:50
Hi all thanks for the replys got a welding job done on the exp tank, so far all good,will still try too get a new one anyway for a spare, Cheers. :y
