Chat Area => General Car Chat => Topic started by: Fabianknutsen on 18 April 2017, 22:20:36
Title: Looking for a new pair of headlights
Post by: Fabianknutsen on 18 April 2017, 22:20:36
Hi, Im looking for some new headlights with xenon, and was wondering if anyone have someone to recommend, and maybe where to buy them ?
Title: Re: Looking for a new pair of headlights
Post by: biggriffin on 19 April 2017, 07:29:04
Do you need new due to accident, or would a good polishing of the lenses sort it.
Post by: tunnie on 19 April 2017, 07:53:01
Or has the adjusters failed on current set?
Post by: Lizzie Zoom on 19 April 2017, 14:27:08
I bought my last two brand new ones from my Vx dealer, but even with TC you cry about the price; it is worth it though for a lovely set of mint, ex-factory  ;)ones! :D :D :D
Incidentally I was told (back in early March) that the o/s one was the last in Luton, and the n/s one of the last 6 :-X
Post by: Andy B on 19 April 2017, 14:37:01
Remember that we drive on the other side of the road so our's dip to the left  ;)
Post by: Doctor Gollum on 19 April 2017, 19:02:17
Genuine retail at circa £280. Each.
Depo are available for around £80-100 each. ;)
Post by: Fabianknutsen on 19 April 2017, 19:19:33
Both level adjusters were broke on the pair i bought. Dont have xenon on my car originally, and was wondering how it is to install xenon headlights when i have halogen ?
Post by: Lizzie Zoom on 19 April 2017, 19:44:23
£243 each withTC :y
Post by: TheBoy on 20 April 2017, 11:52:34
You'd need to check your local laws, as retrofitting HIDs is a grey area in UK, who follow EU rules, so grey area in EU.  But Norway, I have no idea.
Actually fitting HIDs is trivial, its the requirements around washers and levelling that make it hard.
Replacement headlight adjusters available online, about £10-12 each, about 45mins per headlight to fit.
Post by: MonzaGSE on 20 April 2017, 12:05:43
Retrofitting hids is pretty much the same in norway. You have to fit the entire levelling system and headlight washers i believe to make it legal. The projector headlights from around 98 is a better/easier option.
Post by: Fabianknutsen on 08 May 2017, 23:47:37
Have managed to find a pair of xenon headliights, from a 98' dono rcar. Do i have to use the connector from the donor car ? The connections for the xenon light and level adjusters are different from the original headlights.
Post by: Fraggles Rock on 09 May 2017, 00:25:33
You've answered your own question... yes :y
Post by: Fabianknutsen on 09 May 2017, 08:43:47
Haha, quite true  ::)
Have you done this before ? Im wondering if someone have a wiring diagram for this.
Post by: Doctor Gollum on 09 May 2017, 09:18:55
Main beam, side lights and indicators should all be the same. Dipped beam power goes to the blast pack rather than the bulb, hence the different plug.
The levelling motors get swapped with your old ones for functional, but manual rather than auto levelling... Xenons have sensors on each axle and an ecu behind the righthand headlight to replace the wheel on the headlight switch.
Washers have a relay controlled pump. This relay is powered by the headlight feed, ie lights on pump gets power, and pump is switched via the front washers... Separate pump and plumbing to screen washers. Pre/mid facelift washers are telescopic and made from rocking horse poo.
