Omega Help Area => Omega General Help => Topic started by: Entwood on 25 April 2017, 17:15:04
Title: Front wheel bearing
Post by: Entwood on 25 April 2017, 17:15:04
Whats the best source for a Front Wheel Bearing for a 3.2 please ??
Ominous speed related whine started today... goes quiet in right hand turns, louder in left hand turns, so suspect right hand wheel bearing.. but it is persisting down and I ain't getting wet just to check it out !!
Changed 70,000 miles ago ....
Title: Re: Front wheel bearing
Post by: tigers_gonads on 25 April 2017, 17:30:03
I fitted a Lucas one from ECP a couple of years ago Nige.
Seem to remember 65 quid rings a bell.
You will need some scaffolding and a long bar.
Watch out you don't smash the abs sensor when you abuse it off  ;)
Post by: biggriffin on 25 April 2017, 18:49:33
Try Keith abs, he might have one.
Post by: Kevin Wood on 25 April 2017, 20:37:05
Might be worth checking it's not just a sharp edge on a brake pad. :y
Post by: Webby the Bear on 25 April 2017, 21:48:05
Use Vetech (GSF) for pretty much everything due to low cost and lack of warranty claims* :y
*plus when asked what brand I always like to say "in vetech yo". The little things.
Post by: Webby the Bear on 25 April 2017, 22:01:01
I haven't done my front wheel bearing(s) but once hub nut off wouldn't the old unit just slide off? Or are these known for seizing? Most bolt on bearing/hub complete assemblies on other motors just slide off the stub axle after hub nut off.
Post by: Andy B on 25 April 2017, 22:17:17
You've got through some wheel bearings on that car  ......  ::) ;)
Post by: Mr Gav on 25 April 2017, 22:22:55
I used Autovaux with no issues but I would think GSF or Euro Crap Parts would be similar in quality, I think I paid £35 a side.
Front hub nut is 200Nm and the the hub assembly just slides off  :y
Post by: Entwood on 25 April 2017, 22:29:15
I guess you could think that .. but the record shows one front one failed in France (Aug 2011, 108760 miles) and they "insisted" on changing both ... never felt or sounded right and MarkDTM diagnosed a badly made Front Nearside bearing at the "nearly wales" meet in September 2011 so it was changed (110006 miles).
Nearside rear bearing changed in April 2012 (114903 miles)
Now approaching 165000 miles so not to bad IMHO .. :)
Post by: Entwood on 25 April 2017, 22:30:57
Good thought .. hopefully, if its dry tomorrow, I'll find out .. :)
Post by: Webby the Bear on 25 April 2017, 22:33:50
The Makita would call that finger tight  8) ;D
Post by: tigers_gonads on 25 April 2017, 22:43:07
After some serious abuse from behind with a lump hammer  :-X ;D ;D
Post by: Webby the Bear on 25 April 2017, 22:45:00
 ;D
Post by: Kevin Wood on 25 April 2017, 23:42:02
Both of mine are still original at 206k. :-\
Post by: Keith ABS on 26 April 2017, 07:27:22
I have one on the shelf Nige
Keith ABS
Post by: RobG on 26 April 2017, 09:19:04
320Nm
Post by: biggriffin on 26 April 2017, 10:49:48
320Nm
FT and a bit, in old money ;)
Post by: Entwood on 26 April 2017, 15:17:52
Just got all the kit out to look at the problem and it bloody well started to SNOW !!!!!!!!!  All put away and the job will have to wait  ...  :)
Post by: Doctor Gollum on 27 April 2017, 16:46:35
28 degrees here if that helps :D
Post by: Mr Gav on 30 April 2017, 11:19:04
You would have probably hit it with a hammer whether it needed it or not knowing you  :P ;D
Both of mine just pulled off with a small amount of force, no hammer required over here  ;D
Post by: Mr Gav on 30 April 2017, 11:21:37
320Nm
Ah yes...I forgot that my torque wrench only goes to 200Nm, IIRC I did it to 200Nm and then a further 90 degrees.
It was a good few years ago now  ;D
Post by: Doctor Gollum on 30 April 2017, 11:30:49
Big halfords one goes to 300nm which is pretty much enough :y
Post by: Mr Gav on 30 April 2017, 13:23:47
Yeah, I already had my Clarke torque wrench an I wasn`t buying another for two hub nuts  ;D
Post by: Webby the Bear on 02 May 2017, 19:12:56
320nm. 7 dugga duggas  :y
