Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 04 August 2008, 13:39:59
Title: Tyre size
Post by: JamesV6CDX on 04 August 2008, 13:39:59
What tyre size is fitted as standard to a Facelift Elite, I presume my new one has 17" wheels?
Dunno why but I suspect at the price I paid I may be needing to invest in some soon...
Title: Re: Tyre size
Post by: kris9128 on 04 August 2008, 13:40:47
i got 235/45/17 on mine.
Post by: JamesV6CDX on 04 August 2008, 13:49:12
What tyres do you use, and how much do they cost you?
Post by: Jimbob on 04 August 2008, 13:50:49
I had 4 new Continental Sport Contact 3's put on at WIM last week.
£110 each :(
was a lot cheaper than I could find them for locally, plus got the geometry done as well :)  Very happy
Post by: Jimbob on 04 August 2008, 13:53:21
Just checked my emails, he quoted £93 each for Dunlop 9000's
Post by: TheBoy on 04 August 2008, 14:11:30
Should be 235/45/17 on a facelift elite.
Wait and see what they are like - you may be surprised :y
Post by: HNO3GOH on 04 August 2008, 14:15:34
I will be putting 4 new ones on soon and the tyres i put on are called accelara and cost about £45 fitted each and that is at our local bathwick tyres but i do get discount there due the fact that there is five Omega's in the family and two of them do about 60,000 miles a year so we go though alot of tyres so if you do go and have a look they might be a few pounds more. I find these accelara to be a good all round tyre and i got about 26,000 on the front and about 31,000 on the rear :)
Post by: TheBoy on 04 August 2008, 14:19:35
I use Nexen on the tractor, and they are better than the Avon ZZ3s I used to have on under all conditions I've tried so far.
Not sure I would use budget tyres on MV6 - I may have to swap the wheels over with tractor when I get MV6 aligned (mv6 has buckled wheels), so will see how it copes then.
Post by: JamesV6CDX on 04 August 2008, 14:21:24
I had a bad experience with Nexens stepping out... as did STMO.
Budget tyres on a 2.0 are fine but I'm not sure they'll cut it on my 3.0 - I may have to get some goodun's  :)
Post by: HNO3GOH on 04 August 2008, 14:28:41
I really like these accelara tyres and have been using them for a few years now but how do you find the Avon ZZ3s as i have them on my 3.0 (the car come with them on) and i dont like them cos i find that they get a hold of every rut in the road :(
Post by: Danny on 04 August 2008, 14:32:26
i'm on federals at about £75 a corner, not had any trouble with grip, but i very rarely get chance to go over 60mph anywhere so it doesnt matter
Post by: kris9128 on 04 August 2008, 14:35:57
got michelins on a the mo. but need 4 new tyres. let A.T.S in taunton sort my tracking out when they fitted them for me. now they all f*ck*d. only 8000 miles. dont ever let A.T.S near your car.
Post by: TheBoy on 04 August 2008, 14:36:15
Only had the ZZ3s on the back of the tractor. Was always like driving on a greasy road - any attempts to give reasonable power coming off corners resulted in handfuls of opposite lock.  Quick getaways from standing start were also a no-no.  In the wet, they were truely awful.
Post by: Lazydocker on 04 August 2008, 14:36:28
I'm running Accelera Alpha's on the front, as recommended by a friend who has his own garage, and can't really fault them for £50 ish a corner, fitted. They're a bit hard but I've only managed to get them to let go once...... Braking very hard over a large puddle (deliberately) just to see what they do!!!
Apparently they aren't so good on wrong wheel drive cars though ;D ;D ;D ;D
Post by: TheBoy on 04 August 2008, 14:38:31
Thats your problem.  Tracking is a waste of money, as what are you aligning it to?
Get a full geometry done on it (and not 4 wheel alignment etc), before you ruin another set.
Still, ruining the michelins is about the best thing you could do to those tyres - they are not my favourite!
Post by: Jimbob on 04 August 2008, 14:40:06
That was 1/2 my reason for using WIM, despite being 200 miles away
Geomerty spot on, and set of new boots, so no wear issues from day 1!
Post by: TheBoy on 04 August 2008, 14:41:00
I think these ones are the newer CP641 or something like that.  Have to say, I was expecting them to be on a par with the Avons, but they are a revelation!
Done about 3k on them, no wear.  Bearing in mind your old ZZ3s I had were completely wiped out at 4k  :-[
As said, not sure I'd stick them on the MV6 though  :-/
Post by: HNO3GOH on 04 August 2008, 14:46:14
Apparently they aren't so good on wrong wheel drive cars though ;D ;D ;D ;D[/quote
Great tyre james and if you need to change them when you get the car then you wont go far wrong with these and i think when the time comes to change the ones on my V6 then a set of these will be going on :y
Post by: TheBoy on 04 August 2008, 14:49:45
I'd recommend you try the ones of the other car before committing to the choice to the v6...
Post by: Marks DTM Calib on 04 August 2008, 14:50:09
Those Nexen CP641's are cheap enough.....£50+fitting here and 60+ fitting for the 17 inch ones.
Post by: TheBoy on 04 August 2008, 14:52:00
Think I paid £47 + VAT a corner...
Post by: VXL V6 on 04 August 2008, 17:02:25
Dunlop Sport 9090's from WIM - £85 a corner, slightly noisy but very good handling in all weathers so far.
I can't fault Nexen's as a budget choice, had them on the car originally, not in the league of premium brands but still very good.
Post by: Taxi_Driver on 04 August 2008, 18:48:03
Same as im using now.......still like Nankangs NS2's tho......unable to get hold of anymore at a reasonable price.......
I get the Accelara from Bathwich tyres too (Swindon) £47 ea fitted  :y
Post by: Jay w on 04 August 2008, 18:58:09
on the gold one i was using SP9090 Dunlops and paying £90 a corner.....
front set lasted me 20K and the backs were well past 30K before they needed replacing.
Yes they are slightly more noisy than a comparable tyre but the grip and the fact that they wear well more than offsets that
I have SP9000's on the CDX, slightly cheaper and i'm not sure i would go with them again, they still step out on wet days, it seems that stepping out on corners is fairly normal with this one!!! and i'm not hoofing if
Post by: Kevin Wood on 04 August 2008, 20:43:44
Has it been WIM'ed?
