Omega Help Area => Omega General Help => Topic started by: grifter on 22 May 2017, 18:23:08
Hi, I checked the change gasket/clean plenum guide thinking one of them would have values for this, from the settings given I couldn't see anything about torque settings for the inlet manifold bridge, unless reading it wrong, I wouldn't imagine it was 8nm, but again I don't really know. The 6 torx bolts is the value I'm looking for.
http://www.omegaowners.com/forum/index.php?topic=90653.0
Below is what I could find. It's not 8nm is it? :)
Torque Values
EGR pipe to EGR valve 25Nm
Item Value
Plenum to inlet 8Nm
Support bracket to EGR valve 20Nm
Cable tray to plenum 6Nm
Throttle body to plenum 8Nm
Breather bridge to plenum 8Nm
Cheers
G
Where did those numbers come from ???
Link in first post
Is it not in this lot? :)
http://www.omegaowners.com/forum/index.php?topic=90519.0
Fancy that :D
Now that is what I'm torquing about!
Intake bridge to intake flange - 20nm
