Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: zirk on 06 June 2017, 20:56:01
Title: Wanted, Fuel Return Hose from Injector Rail.
Post by: zirk on 06 June 2017, 20:56:01
Not sure if its the same as the Fuel feed Pipe to the Injector Rail, but the Return Pipe will do for me as I can get to it easerly without ripping Air flow Pipes off on a 2.2.
Pic below (Not a real Pic) may not need the whole pipe, if its been cut, just need the screw in part with enough rubber hose that I can bend and attach another hose to it. :y
(https://d3vl3jxeh4ou3u.cloudfront.net/1%20-%20How%20to%20Replace%20a%20Fuel%20Return%20Hose%20-%20fuel%20return%20hose.jpg)
Title: Re: Wanted, Fuel Return Hose from Injector Rail.
Post by: omegod on 06 June 2017, 22:12:57
Should have one on the 2.2 I'm breaking, will check tomorrow  :y
Post by: zirk on 06 June 2017, 23:05:44
Ok Thanks, its the one towards the front of the car, although if your breaking it, I may buy both of them of you.
