Omega Help Area => Omega General Help => Topic started by: omegod on 30 June 2017, 11:49:39
Just checking as not with the car, undo 2 bolts through the hub and strut, pull hub assembly forward then 3 nuts on top of inner wing and the strut should come out?
3 nuts on top? Just one big one isn't it?
Two that hold it to the hub carrier, one big one on the top and the anti-rollbar droplink.
The ABS wiring is attached to the strut as well.
You will need to have the geometry done once you've reassembled everything.
Wot Nick W says ^^^ :y
Or mark the position of the bolt heads on the strut for the pikey method. Though if it were my motor I'd get geo done too :y
