Chat Area => General Car Chat => Topic started by: LFF64 on 19 July 2017, 19:45:59
Title: Ford Focus 2015
Post by: LFF64 on 19 July 2017, 19:45:59
Does anyone know how to get in too a keyless entry Focus that has a flat battery
My friend says they have just a fob
I looked online and found something which involves taking the fob apart and then there is a key blade inside which can remove a cover and then exposes a lock barrel
Any ideas guys  :y
Title: Re: Ford Focus 2015
Post by: STEMO on 19 July 2017, 19:53:04
On the wife's Renault: There is a button you press on the side of the key fob which releases a blade. There is a keyhole on the passenger door which you put the key in. Voila.
Post by: STEMO on 19 July 2017, 19:58:17
Don't know why you guys can't use google
http://fordstnation.com/focus-st-general-discussion/6253-keyless-ignition-backup-key-blade-alt-starting-lock-procedures-if-key-fob-dead.html
Post by: Nick W on 19 July 2017, 20:03:16
http://fordstnation.com/focus-st-general-discussion/6253-keyless-ignition-backup-key-blade-alt-starting-lock-procedures-if-key-fob-dead.html (http://fordstnation.com/focus-st-general-discussion/6253-keyless-ignition-backup-key-blade-alt-starting-lock-procedures-if-key-fob-dead.html)
One thing to consider with any older car that is always locked off the fob is that there is a good chance that the key lock will be seized if you need to use it.
Post by: STEMO on 19 July 2017, 20:11:28
That shouldn't be the case in a 2015 car though.
Post by: Lincs Robert on 19 July 2017, 20:40:26
I have this as an option on my 2012 Mondeo, there is indeed a key blade inside the key for.
Post by: tidla on 19 July 2017, 20:52:42
Do you still have to open the bonnet on these things with the key?
Post by: LFF64 on 20 July 2017, 00:01:39
I did look online but was just checking in case anyone had any other information or advice , the example you found is for American cars as was the one I found
Post by: BazaJT on 20 July 2017, 07:54:37
Yes that link is correct,although you can put the "T" piece of the blade into the fob[so the blade is at right angles to the fob]and then you've got the fob for a little extra leverage.No Tidla the bonnet release is now on a lever inside the car instead of in the grille-Transits may still be an exception,but I've not looked at one of those for a while.
Post by: TheBoy on 20 July 2017, 17:53:13
Jag is same, a real key hidden in the fob.
The manual lock is hidden on passenger side though, not sure if that's because it needs mucho friggin and safer to do from pavement, or (more likely) designed for the Shermans. Hence bonnet release is that side.
Post by: BazaJT on 20 July 2017, 19:20:04
Possibly put them on [our] nearside for the European and important- in Jags case the -the American markets?
Post by: LFF64 on 21 July 2017, 12:51:50
Thank you for all the help once again very helpful and she managed to get in to the car  :y
