Omega Help Area => Omega General Help => Topic started by: sjc on 19 August 2017, 09:50:44
Title: 3L V6 into 2.2 (petrol) facelift - easy or difficult?
Post by: sjc on 19 August 2017, 09:50:44
I've come across a facelift 2.2 petrol CDX going very cheap that is almost entirely rust free - tiny amount of surface rust at lower edge of rear door shuts that could easily be stopped in its tracks.
Trouble is, the current owner is removing the engine and gearbox for a classic car project.
I have a spare 3L V6 engine and box, but is it an easy transplant?
Guessing the front clip will need to be changed out, but what about things like the exhaust hangers, inner wing mounts for header tanks, etc.?
Title: Re: 3L V6 into 2.2 (petrol) facelift - easy or difficult?
Post by: Kevin Wood on 19 August 2017, 09:59:08
It will be quite involved. 2.2 was DBW whereas the 3.0 is a cable throttle, so the pedal assembly will need to be changed. ABS unit probably won't talk to the 3.0 ECU, so that would need to come from a cable throttle V6 and not sure if the 2.2 ABS was 4 channel.. so maybe some extensive wiring and brake plumbing to do.
Diff ratio will be wrong for the 3.0 for anything other than drag racing, most likely.
Instrument panel is different but not sure if that can be config'd to suit a 4 pot using tech 2. :-\
Not sure if engine mounts on the front subframe were the same or if that was different...
Complete engine / transmission loom from the 3.0 would be needed and you'd have to be careful that everything connects correctly to the car loom as you're mixing 2 generations of engine electronics.
It's not the job of a weekend. If it was going to that hassle, I might be tempted to make the new engine a V8 instead... 8)
Post by: Doctor Gollum on 19 August 2017, 10:34:59
Or fit a Z20LEx  ;)
Subframe will be fine and loom should be plug and play :y
Again not a weekend job, but certainly more feasible...
Post by: biggriffin on 19 August 2017, 10:54:47
Sub frame,engine loom,  Ecu, abs ecu, pedal box, gearbox,  if auto then gbox ecu, gearbox loom should be the   same.
Post by: sjc on 19 August 2017, 14:25:23
Hmmm... not sounding like a go-er.
Might just buy it for the 4 good doors.
Thanks for the replies.
Post by: tunnie on 19 August 2017, 19:04:18
If it's rust free pop another 2.2 lump in there? With a manual gearbox they are not bad going, they are also a sheer pleasure to work on thanks to space around them.
Post by: sjc on 19 August 2017, 20:09:35
Good point Tunnie.
Also liking the idea of a 20 LET lump
