Chat Area => General Car Chat => Topic started by: pauls on 21 October 2017, 12:49:25
Title: headlights
Post by: pauls on 21 October 2017, 12:49:25
https://i.ytimg.com/vi/WWX_El28pIw/hqdefault.jpg
Can anybody help please Iam trying to find a replacement lense (dome Glass).
On the linked picture its the middle lense that i need. mine are cloudy and all though i have put the high out put osrams in its still not that bright.
Any help or links would be helpful as i have spent all morning trying to find them.
P.s these are not xenon.
Title: Re: headlights
Post by: grifter on 21 October 2017, 15:45:15
Not sure if you can take those out, i think the light is generally one piece and you need replacement light.
Post by: annihilator on 21 October 2017, 16:11:46
Depends what it's off,omega ones are removable. :y
Post by: pauls on 21 October 2017, 16:50:24
they are on my audi b6
Post by: grifter on 21 October 2017, 17:30:24
Had a look at mine and they appear pretty much glued together, the lens. Are you saying lens can be removed,on omega?
Post by: cam.in.head on 21 October 2017, 18:48:23
If you are lucky and the clouding is on the inside face you can get a rag/cottrn wool rtc etc in through thr back without dismsntling and clesn it off. When i did mine (headlight was removed for ease) they were very cloudy but only on the inside face for some reason! . So easy to clean.if they are on the other side then you may need to remove front cover.see guide.if you go to the trouble of removing front cover then be 100% sure the adjusters are good (top mount) because whilst you are in there .! ,!
Post by: cam.in.head on 21 October 2017, 18:58:43
Sorry about the spelling! Ipad seems to change stuff willy nilly!.  Before i did my lights they were very poor with a non defined dull beam (hid's too) after cleaning the domes and polishing the outer plastic covers they are transformed so worth the effort.
Post by: Nick W on 21 October 2017, 21:03:56
Easiest way is to stick them in the oven on a low heat for 5minutes. This reactivates the adhesive, and you can gently pry the lens off. I put them back for another couple of minutes when I've refitted the lens to ensure that it's sealed.
Expect to find broken adjusters if you haven't already replaced them.
Post by: pauls on 22 October 2017, 19:17:15
Right quick update. I managed to brake these down today i was shocked to find the reason for the cloudy look wasnt because the the projector lens was dirty it was due to firstly the angle you looked at it ,the second was the metal plate that blocks half the light thats sits between the bulb and projector. After a bit of googling it turns out its the light director for which country you are in.
Post by: annihilator on 24 October 2017, 05:57:25
Same as omega then.
