Chat Area => General Car Chat => Topic started by: grifter on 23 January 2018, 21:49:32
Got an old cavy with the 1.8 rice pudding skin non-puller in it. I'm wanting to change this over to a SRI 130 engine I got from a pre-cat model. I've read up on various sites about updating the car details with DVLA regarding emission testing but I'm still not clear on it.
From what I gather, I can change the engine over, tell DVLA that the car has this new engine, have to get a confirmation from VX using engine number that it is pre-cat, give this to DVLA and they will update their system so that when I go to MOT and they put car reg in it will say no cat test required. Has anyone any knowledge if this can be done like this?
I'm kind of half doing this because had all sorts of probs with emissions (car runs fine) but it just happened that this engine was the only one available in my area at the time, complete engine, box and loom with ECU, not to be sniffed at out of an SRI 130.
Just drop it in, and crack on, don't bother with all the faffing around, as long as it passes the not, why bother.
Yep, I believe emissions should be based on the age of the engine, so if you can prove the engine is dated pre -1992 you should be OK.
If I pretend it is a 1.8 but go in with a non-cat 2.0 under the hood there is every chance it might not pass.
No, it won't pass as it will be listed as cat equipped. You either need to swap the engine management onto the new engine and run it with a cat or obtain evidence that the engine is old enough not to need a cat.
Also my understanding.
Looking forward to my 'visual smoke test' should I ever get the kit car on the road (1969 engine block) ;D
It's getting to the point where it'll need to pass an "aviating pigs test". ::)
Or fit lpg :D
:-[ :-[ So true. By the time it's near completion, cars will have been banned and it'll make a nice ornament. Or coffin.
Or fit lpg :D
I know someone with an LPG'd Cobra.. I've also seen LPG'd TVRs. The small boot would be very small after that, though! ;D
Or fit lpg :D
Or fit lpg :D
I think you should leave some space for a Mr. Fusion. Should be commonplace 2nd hand on Ebay by the time it's on the road. ;D
Unless DVLA has been notified of the engine change and they have proof from VX the engine is pre-cat they then update the car details so that when the MOT comes and they put reg in the machine it says no cat test required, or something along those lines. This is what I had read and wanted to check if anyone had actually done this.
If I pretend it is a 1.8 but go in with a non-cat 2.0 under the hood bonnet there is every chance it might not pass.
FTFY! ::) :P :)
FTFY! ::) :P :)
Thanks, I couldn't be bothered myself :)
