Chat Area => General Discussion Area => Topic started by: zirk on 10 April 2018, 19:42:43
Its no substitute for Olive Oil and .......its No Good for blocked Ear Wax issues. :'( ::)
RedTube on the other hand will unblock even the most bloked of pipes. :o
What Redtube are you talking about Chris ? :o
Bloke pipes? Nothing like bloky pipes! :D :D ;)
Aye, that 'n all! ;D ;D
Not Redtube, the plastic Red Tube Syringe thing that plugs into the top of the WD40 Can, you know so you can squirt it all in one direction. .....like an Ear Drum.
You're not quite grasping the idea here are you?The W in WD stands for water not wax 8) As it says in all the best adverts.....Always read the lable :D ;D ;D ;D
I did read the Label, its said nothing about containing Nuts, dont squirt in your Ear, or Nozzle Pressure and db Noise Level. Do you know how Fudking Loud an Aerosol going off inside your Ear Drum is. :-X
Well now you mention it no I don't :D and I hope you'll forgive me if I say that I'm willing to forego the pleasure of finding out ;D
I bought some Moroccan oil for my tinnitus when I was in...err.... Morocco. It burnt through my eardrum like battery acid and I ended up in hospital for treatment. Apparently you are supposed to dilute it. ::) On the plus side there was no earwax so earwax clearly doesn't like battery acid.
Got me worried then with "RedTube" and poky things :o
This is all a bit Darwin' ian ;D
Why not just go to the chemist and get the right stuff?
April 1st has gone, but this surely must be a wind-up?
PLEASE assure me that you didn't really squirt WD40 in your lug'ole? :o
Ron.
