Omega Help Area => Omega General Help => Topic started by: omegajohn on 21 April 2018, 16:45:01
Title: what size socket for diesel injector 2.5td
Post by: omegajohn on 21 April 2018, 16:45:01
just need to know for definite if its a 27mm socket i need to get and i am sure someone here will know
Title: Re: what size socket for diesel injector 2.5td
Post by: TheBoy on 21 April 2018, 18:23:48
Its the largest of the "standard" injector sizes, so I believe you're right at 27mm.
If its injector 4, it needs to be one of those crappy injector sockets due to the sensor.  Any other, use a deep normal socket, as the injector ones are inherently weak.
Post by: omegajohn on 21 April 2018, 21:00:12
Thanks The Boy for your advice ... yep it is  injector 4 the one with the wire just don't want to waste my money buying a set that i will never use.. getting fed up of changing these wired ones and borrowing tools and i've got a good one in my donor car just need to whip it out . going to buy one then it can sit in my tool box till next time.
 i do an omega  its the 5th one i have had i'm  6ft 5" so plenty of legroom   take care ,thanks again,    john.
Post by: raywilb on 22 April 2018, 23:30:03
  I have a couple , one of them is for No 4 which has the cutaway slot. if you need them let me know :y
