		Omega Help Area => Omega General Help => Topic started by: judge_dredd65 on 21 June 2018, 13:19:42
				Hi Guys,
Can anyone tell me are the heads in a 2.5 the same as the 3.2?
If not are the camshafts interchangeable?
Thanks in anticipation
				No, the combustion chamber on the 2.5 heads is smaller than the 3.2 and the inlet tracks slightly narrower.
You can fit them (check they are a post 1997 head with the additional webs between cam areas to take the coil pack bolts) on a 3.2 to raise compression back up to that of the 3.0 but you will need to port the inlet slightly to match the inlet divider.
