Omega Help Area => Omega General Help => Topic started by: swordfish on 14 July 2018, 10:08:57
Title: 3.2 fuel pump removal
Post by: swordfish on 14 July 2018, 10:08:57
Hello ,,
can somebody please explain how you remove the fuel pump from the plastic case it sits in ,, it's out of the tank on the bench but carn't see how i remove it from the plastic case  ??? ???
Thankyou
Title: Re: 3.2 fuel pump removal
Post by: terry paget on 14 July 2018, 12:19:08
I have had mine out enough times, but on reflection they have stayed in their plastin containers. Here are my 2 spare pumps, still in their plastic holders.
(https://www.dropbox.com/s/mlmazhuyu9cmx5v/FUELpumps.jpg?dl=0https://www.dropbox.com/s/mlmazhuyu9cmx5v/FUELpumps.jpg?dl=1)
Post by: terry paget on 14 July 2018, 12:20:15
(https://www.dropbox.com/s/mlmazhuyu9cmx5v/FUELpumps.jpg?dl=1)
Post by: Doctor Gollum on 14 July 2018, 17:25:48
Have you actually looked at it ???
Post by: Jan Suhr on 20 July 2018, 13:28:09
The electric pump itself sits in a smaller insert in the big housing. There are a couple of small tabs ( I think it is 3 ) that you push to the center and then you can pull it out of the outer big housing.
Then to replace the pump motor there is three other tabs that holds a cover that keeps the pump in its enclosure. Those tabs are sort of having saw tooths that keeps it in place, you have to slightly bend them apart to pull up the cover that holds the pump. When that is done you can get the pump motor free.
Hope this helps
Jan
Post by: Doctor Gollum on 20 July 2018, 15:05:49
And all obvious to the naked eye ::)
Post by: Diamond Black Geezer on 20 July 2018, 17:36:46
The strainer/teabag on the underside needs to come off. .... "they just pull off", so I had a duff pump...and the plastic collar just snapped on me! i am a methodical, pragmatic, non-ham-fisted sort of James Mayish person. So take it steady, I'd suggest a twisting action, also pry it down with a flatbladed driver, don't strain the plastic collar inside. Did another one that way and came off a dream.
As above squeeze/pinch the tabs in, you can do it one tooth at a time, then move round, do the next, and so on.  :)
