Chat Area => General Discussion Area => Topic started by: BazaJT on 04 August 2019, 07:57:39
Title: Dave the Builder
Post by: BazaJT on 04 August 2019, 07:57:39
C'mon lad get your backside in gear and pop over to Whaley Bridge and show them how to carry on sorting their dam out. Don't forget to take your wellies in case it lets go though.
Title: Re: Dave the Builder
Post by: Varche on 04 August 2019, 08:32:06
Yep two large sheets of plastic ( one for the inside and the other for the outside). Plus a large tube to syphon the water out
Post by: Kevin Wood on 04 August 2019, 10:18:41
I notice how the news talked about "engineers" having turned up to fix it. They'll be the ones carrying the shovels, then. >:(
Post by: Sir Tigger KC on 04 August 2019, 10:29:19
Give the man a chance Baza, he hasn't finished his tea yet!  :o  ;D
Post by: Sir Tigger KC on 04 August 2019, 10:31:01
I bet whoever did the last inspection has had a twitchy ring these last few days!  ::)
Post by: dave the builder on 04 August 2019, 10:47:40
I live on top of a big hill 60 miles away ,so I'm not getting involved  ;D :D
plus ,it's bad enough getting my Omega wet when it rains  ;D
Post by: Kevin Wood on 04 August 2019, 12:36:22
Yep, wouldn't fancy being in his shoes, especially if the local residents discover him. :o
Post by: Migv6 le Frog Fan on 04 August 2019, 12:41:43
Pis in one of todays papers from a year or two ago,show small trees growing through the part which has now collapsed. Suggests a lack of ongoing maintenance ?
Post by: Nick W on 04 August 2019, 12:48:54
The root cause?
Post by: dave the builder on 04 August 2019, 13:19:46
plants growing in expansion joints (a bit like weeds growing in between block paving ) makes little difference when you have massive flows of water under the slipway ,washing out the sub-strait  :y
the slipway is just a small section of the retaining "dam" , i'm sure they will find later that many other sections require beefing up .
I'm surprised the concrete is so thin on the slipway though ,I've seen better shed base pours  :P
as with the other national infrastructures ,like gas and electricity , massive investment is required to the network ,but now the water,gas and electricity is in the hands of the private sector ,shareholder profits are more important than  safety or longevity.
I've recently installed a 5 stage filter system on my kitchen tap after seeing the filth that my drinking water filters and Koi pond top up filters captured  :o
that "linescale" in your kettle proves interesting when you test water quality for nitrate,nitrite,PH,lead/heavy metals,chlorine,chloramine, amonia, and tds in general  ::)
Post by: STEMO on 04 August 2019, 15:52:38
And yet we're all still here.  ;D
Post by: Sir Tigger KC on 04 August 2019, 18:39:22
Just...  ::)                                                           ;)  ;D
Post by: dave the builder on 04 August 2019, 18:56:08
We all used to lick lead paint off our toys,play with mercury,suck lungs full of lovely asbestos and coal dust  etc etc  :P
Post by: Viral_Jim on 04 August 2019, 19:21:44
You forgot the half dozen cans of squeezy foam. Every builder I've ever met seems to love that stuff.
That said I've just been using some on our place so I'm hardly in a position to judge.  ::)   ;D
Post by: Varche on 04 August 2019, 20:56:31
Squeezy foam. That would be a brilliant solution. I would expect sections of rebar brayed in every so often too. In Spain the builders have a useful finishing product called Caucho. It is like a rubber liquid you paint on to keep water out ( or in)......
Post by: Viral_Jim on 04 August 2019, 21:10:28
Apparently a light misting of water helps with the curing process...
Sounds ideal really  ;D
Post by: dave the builder on 04 August 2019, 21:29:40
It's not UV stable
It is a good product for some situations ,this DAM leak is not one of them  ;D
sticking plasters on the outside of a leak rarely ends well
I'm sure there are plenty of engineers on the case now with a plethora of new products to try use successfully  :-X
Post by: Varche on 04 August 2019, 22:16:52
It's not UV stable
Not wanting to rain on your parade ( or whatever the expression is!) but is there actually a leak?  Just a bit of concrete crumbling a bit because the dam was full to overflowing.
A lot of foam, rebar and some caucho over the top and job jobbed.  The hard work has been done by helicopter men. These engineers will just come up with some great costly scheme that will cost twice the agreed budget to implement
Post by: dave the builder on 04 August 2019, 22:38:35
But under the concrete slipway is just ground that will erode very quickly
needs draining down enough to engineer a strong concrete slipway and puddling clay inside ,deep enough so the water does not go under the slipway
water will find it's own level,it will sneak through the smallest of gaps and carve a bigger path over time.
sand in the bags that Boris did will not last  ;D
a missed small scale hydro-electric  power opportunity on the long term solution too  i'd imagine  ;D
Post by: Varche on 04 August 2019, 23:02:33
HEP. You have persuaded me.
We live near a huge 10 mile long lake and it has a hydro electric power station. Quite small as it is sized for minimum flow throughout the year
Post by: Rods2 on 05 August 2019, 09:23:56
It must be a bit of a shock for the RAF, being brought in to stop the breaching of a dam instead of creating them. ::) ::) ::)
