Omega Help Area => Omega General Help => Topic started by: kfashley on 08 August 2019, 17:20:38
Title: Door card removal
Post by: kfashley on 08 August 2019, 17:20:38
Hi everyone.
My 2003 2.6 estate door solenoid stopped working.the drivers door would open and lock with the key and the remote worked on the other doors so I was not going to bother getting it fixed. Then the  locking tab on the door started staying down, again no problem until I found that occasionally I could not get the door open from the inside or outside and had to get out through the passenger door. I have replaced the solenoids on other Omegas but not the facelift model. I have removed all the screws including the one under the plastic interior door lever. Do I have to take off the decorative wood finished panel. Do I have to remove the door light. On the new site I cannot get access to the advice and videos formerly available on the old site.
Can anyone help. I did manage to get the door tab up by pulling hard with pliers locked on with the window down.  I tried to release the window opening switches by levering up as was necessary on the old model and must have dis connected the switch as I cannot get the window to close and it’s raining tonight!
Title: Re: Door card removal
Post by: TheBoy on 08 August 2019, 17:22:59
No need to remove fake wood.  Full instructions are in Maintenece Guides section
Post by: TheBoy on 08 August 2019, 17:24:15
Specifically http://www.omegaowners.com/forum/index.php?topic=90514.0 if you CBA to look
Post by: Andy B on 08 August 2019, 17:44:57
There is a lot of stuff in there & if you don't know it's there, it can be hard to wade through it all  ;)
Post by: TheBoy on 08 August 2019, 17:59:19
Hence I gave the link to the specific guide ;)
Post by: robson on 08 August 2019, 17:59:44
Open the cubby door in the door card,  at top by catch you will see a plastic cover about 2inches long, prise this out and there is as screw under there, unscrew and door card will release. no need to remove light.
Post by: robson on 08 August 2019, 20:44:41
you do realise that the top of the door card clips into a channel on the door push the door card up to release.
Post by: robson on 08 August 2019, 20:47:10
what is your location there may be somewhere near that can help.
Post by: Doctor Gollum on 08 August 2019, 22:02:11
Thank goodness there's an index :D
Post by: Andy B on 08 August 2019, 22:40:31
If you know what you're looking for ...... :-*
Post by: Doctor Gollum on 08 August 2019, 23:07:33
Door card removal--Facelift is a reasonable hint :D
Post by: kfashley on 09 August 2019, 09:58:27
Problem fixed
Thanks to The Boy, Andy B, Robson and Doctor Gollum
