Omega Help Area => Omega General Help => Topic started by: Stevelaw67 on 21 September 2019, 14:00:32
Title: Headlamps help
Post by: Stevelaw67 on 21 September 2019, 14:00:32
Looking for both uk headlamps for my omega B 2002 part No’s R/H 9193420 & L/H 9193419 need clear lenses for mot
Title: Re: Headlamps help
Post by: Doctor Gollum on 21 September 2019, 14:12:50
You can refurbish the headlight lenses easily enough with very fine wet and dry and G3 rubbing compound.
Requires about 15 minutes elbow grease each side :y
Obviously mask the surrounding body work when  you use the wet and dry  ;)
Post by: DrAndyB on 21 September 2019, 14:29:32
Yep, done this a couple of times on my dads FL Desmond.  Can also pop the light off as well - Relatively easy if i recall.
Post by: TheBoy on 21 September 2019, 14:53:29
Or if you are work shy, use the £18 3M headlight restorer kit that fits in a drill.  I spend about 20mins a side, and it does a better job that spending the same amount of time doing it by hand.
I did my Omega's ones again for the MOT, its surprising how you don't notice that they have gone a bit cloudy until you refurb one of them ;D
Post by: kevinp58 on 22 September 2019, 17:05:23
Yup the Scotch 3M kit works very well I did mine and they came up like brand new
