Omega Help Area => Omega General Help => Topic started by: stuvaux on 13 November 2019, 20:34:09
Hi,
My Omega needed jump starting last week. I thought it may be a one off but the next day it wouldn't start again so i replaced the battery. Now the same thing happened today with the new battery. Managed to jump start it with a booster and it has started fine the couple of times I have started it today.
It seemed to definitely be a battery issue but now I'm not so sure. Is there anything obvious to look for that may be draining the charge?
Thanks,
Stu
the guide in the maintenance section may be helpful
see
http://www.omegaowners.com/forum/index.php?topic=90619.0 (http://www.omegaowners.com/forum/index.php?topic=90619.0)
see
Great thank you, will give that all a try tomorrow. I had only done the basic voltage checks :-\
Although many new batteries come partially charged, it is always a good idea to fully charge a new battery before use - preferably with a 'smart' charger rather than a standard charger. When a battery is very low, it isn't a good idea to use the alternator effectively as a charger; they should be charged to capacity using a smart charger, and when fully charged the alternator can take over when in use on the car.
Every Omega I have owned always seemed to have a greater than normal battery drain when not in use. By this I means periods of several weeks. There never seems to be any fault with them; it just seems to be a characteristic that the battery needs regular 'top ups' when not in regular use.
Thanks for the reply and information :y
alternator is the obvious place to start
