Omega Help Area => Omega Electrical and Audio Help => Topic started by: thebeast on 01 March 2020, 17:57:10
I have a omega CD, can I add HD headlights to Upgrade, is this possible?
If you mean retro fit xenons, then technically yes.
But as a legal minimum you need to also retrofit headlight washers. To do it properly you need the light loom, ecu and level sensors from the nearside suspension as well.
Or you could clean the lenses and fit decent bulbs... Osram Night breakers should be your starting point :y
Fitted osrams in the Saab,, what an improvement,, :y
