Chat Area => General Car Chat => Topic started by: Raeturbo on 09 May 2020, 13:53:19
Title: Random misfire fuel pump/injection relay
Post by: Raeturbo on 09 May 2020, 13:53:19
Anybody know if the corsa fuel pump / injection relay will fit 3.2 mv6.    Their the same colour  ;D ;D car is playing up struggling to start and random misfire when going along.
Title: Re: Random misfire fuel pump/injection relay
Post by: Sir Tigger KC on 09 May 2020, 13:59:26
It could be that one of your dis packs has caught the corona virus Rae!   :D
Or that they're drowning in oil 'cos your cam cover gaskets are leaking...  :(
Post by: Raeturbo on 09 May 2020, 14:03:25
No oil there Steve, James done em👍 Dis packs are only a year old too, I suspect fuel problem the way it’s acting it’s more of a stumble than a definitive misfire
Post by: henryd on 09 May 2020, 14:13:15
Blocked fuel filter possibly, relay either works or doesn't so wouldnt suspect that, if in doubt bridge it feed the pump continuous to see if it helps
Post by: Migv6 le Frog Fan on 09 May 2020, 14:13:36
Check if the numbers on top of the relay match, or just plug it in and see what happens.
Post by: Raeturbo on 09 May 2020, 14:14:26
                I’ll try it what numbers do I bridge
Post by: henryd on 09 May 2020, 14:15:35
Not a clue ::) with out seeing wiring diagram :y
Post by: Sir Tigger KC on 09 May 2020, 14:18:50
That's good.  :y  I hated changing cam cover gaskets!   ::)
Post by: Raeturbo on 09 May 2020, 14:43:15
Think it’s 30 and 87 going out to try now👀
Post by: Doctor Gollum on 09 May 2020, 14:46:37
Check codes and report back.
Use pedal trick if you have two working feet ;)
Post by: Nick W on 09 May 2020, 15:12:00
Relay is almost certainly the same.
It won't cause a misfire though.
Check the entire ignition system first, then the intake for air leaks. If those are all OK, measure the fuel pressure. THEN you start on the injectors and their wiring.
Post by: Raeturbo on 09 May 2020, 15:38:47
Tried the corsa relays they don’t work they are different. Bridged original relays no difference put it back to normal took it for a spin and it’s flying and tick over is perfect. Wonder if I’ve moved something around when I was fu(ing about with it and now it’s ok again, doubt it will last though. Running terrible on LPG then when I switch back on petrol it terrible too but switch it off start again and it’s ok, I have a two second flash on the lpg light which I will investigate. As for the pedal trick what do I do for that then? MV6 3.2. 2003
Post by: Doctor Gollum on 09 May 2020, 15:51:32
Really? There's a guide ::)
Post by: Raeturbo on 09 May 2020, 16:40:31
Ok I’ll search it now :y
Post by: Raeturbo on 09 May 2020, 17:49:44
Right done 10-6-5-10
Post by: Raeturbo on 09 May 2020, 18:05:38
P0650 Malfunction Indicator (MI) Control Circuit High Instrument
P0650 Malfunction Indicator (MI) Control Circuit Low Instrument
P0650 Malfunction Indicator (MI) Control Circuit Open Instrument
      WTF? ;D :D
Post by: Sir Tigger KC on 09 May 2020, 18:26:27
      WTF? ;D :D
I told you from the start. It's got the corona virus!  :)
Post by: Raeturbo on 09 May 2020, 18:33:49
,,     Arhhhhh   ,,
Post by: Doctor Gollum on 09 May 2020, 21:02:31
EML should be on. If it isn't, replace the bulb and report back :y
Post by: Raeturbo on 09 May 2020, 21:17:33
Was on yesterday gone off now would that cause all this crap then?
Post by: Doctor Gollum on 09 May 2020, 21:30:56
Ok that saves having to change the bulb then :D
To answer your question, probably.
Chuck a can of Wynns fuel treatment topped off with a tank of V Power , rag the balls off it and report back ;)
Post by: Sir Tigger KC on 09 May 2020, 21:47:32
Oooo I love it when you get all technical Al!  :y        ;D ;D ;D
Post by: Doctor Gollum on 09 May 2020, 22:03:07
 ;D
Post by: Raeturbo on 09 May 2020, 22:08:34
                 I can assure you the car gets plenty of exercise, and to be honest it does seem to have started after I give it a fair old outing on thursday💀 and I treated it with some redex injector cleaner a fortnight ago👍 And I only ever use she’ll V power in all my fleet
Post by: Doctor Gollum on 09 May 2020, 22:19:44
In that case, it may simply be a bit too much exercise after a bit too much sitting around...
Post by: Sir Tigger KC on 09 May 2020, 22:43:51
Nah it's fooked!  :P  :D  ;D
Post by: Raeturbo on 11 May 2020, 11:56:41
Well the car has fixed itself on lpg and petrol ????? I’m sure there’s something supernatural about cars👀😂
