Omega Help Area => Omega General Help => Topic started by: tooleater on 22 July 2020, 15:32:22
Hi guys, can someone confirm is the connector wiring block to lower fan switch on rad, circular, I can only see the upper fan temperature sensor/switch which is rectangular, I've tested this and all fans are good, I just can't see the lower one as I want to replace both.
Three pin in a T shape iirc :y
Upper one is rectangular-but can have either two or three connector pins o make sure you check which one you need.The lower one is circular with as DG says three connectors in a T shape pattern.
Cheers guys, that's a big help, least now I know what to order for the secondary switch. apologies for late reply. Dickie stomach :-[
(https://i.postimg.cc/HxbXYMGy/IMG-20200723-164624.jpg)
Here's a handy photo :y
