Chat Area => General Car Chat => Topic started by: gbh on 25 July 2020, 15:43:14
Title: Vauxhall Astra Key
Post by: gbh on 25 July 2020, 15:43:14
My elderly friend has just got himself an Astra and it only has the one key so I said you ought to get another asap,he just called me back to say Vauxhall had quoted him £160 for said key so any help or advice I can pass on to him as a cheaper alternative REG BG57VLD
Title: Re: Vauxhall Astra Key
Post by: Doctor Gollum on 25 July 2020, 16:34:37
That's about half what a Mercedes key costs :-X
Post by: TheBoy on 25 July 2020, 17:30:47
£160 is not unreasonable at dealer prices TBH. Most dealers want £80 just to plug the gear in.
Smells like an Astra-H, so probably £40 for blank key, and probably around £40 for an indie to program.
Post by: gbh on 25 July 2020, 17:53:05
Yep it's the twintop 2007 model £80 is a hell of a lot better than £160 that's for sure,would a locksmith be able to provide?
Post by: Doctor Gollum on 25 July 2020, 17:55:05
In that case, I would be more concerned about a working, leak free roof :D
Post by: gbh on 25 July 2020, 18:02:35
Spot on with the roof as it doesn't work and hopefully doesn't leak!!!!!
Post by: TheBoy on 25 July 2020, 18:57:17
As said, acquire the correct key from online sources and find a suitable indie to program.
Post by: Andy B on 25 July 2020, 20:19:53
programme .....  :-X ::)
Post by: Keith ABS on 26 July 2020, 08:25:43
 I do believe Timpsons can supply and programme. Quoted me £65 for an extra key for my 07 plate Zaf B
Post by: TheBoy on 26 July 2020, 09:54:19
No, to configure or write is the americanised program.  On the TV, you watch a programme.
Same as your computer has an americanised disk, but anything else round and spinny is a disc.
Most IT shite has standardised on the (incorrect) American spellings.
Post by: Andy B on 26 July 2020, 14:12:32
;D
Post by: deviator on 27 July 2020, 09:36:42
Be careful of places like this, as they tend to 'clone' the current key rather than adding an additional key properly. This often means that if the spare isn't used for a few months, it will no longer be in sync with the ECU, meaning unlocking with the key and then re-syncing (with the alarm going off). It's better than nothing, but far from great.
Post by: Doctor Gollum on 27 July 2020, 22:33:15
Without the Car Pass or knowing that the key etc is original to the car, a cloned key is your only sensibly priced option ;)
Post by: Nick W on 27 July 2020, 22:49:09
'dangle berries'
Post by: Doctor Gollum on 27 July 2020, 23:31:50
'dangle berries'
Which bit?
If the keys/transponder isn't original to the vehicle, you can't expect the dealers to reliably produce working keys.
Granted the Omega is relatively straightforward because all three parts of the key are individual, and someone with a Tech2, and knows how to use it, can readily reprogramme the chip/remote parts...
Post by: cam.in.head on 28 July 2020, 17:42:50
timpsons halifax are pretty expensive now. quoted me approx£160 for an omega key supplied and programmed when i asked them at the weekend.( lad did ask wether i wanted it to work the central locking or just start the car so he may not be fully clued up !)
Post by: TheBoy on 28 July 2020, 18:14:23
Key cloning isn't really viable if you ever want to use the extra key, as it wont unlock car.
