Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: fudgee on 11 October 2020, 10:11:24
Title: F/L front O/S Door latch required
Post by: fudgee on 11 October 2020, 10:11:24
Hello guys  :)
I need a replacement front drivers side door latch for my 2.2 C.D Auto
Part number is 605328
Many thanks
Title: Re: F/L front O/S Door latch required
Post by: biggriffin on 18 October 2020, 11:05:19
I think you mean the door solonoid.
 https://m.ebay.co.uk/itm/Engine-Closing-Centralized-Front-Right-OPEL-Tigra-605328-AC240-Price-Ex/313228484671?ul_ref=https://rover.ebay.com/rover/1/710-53481-19255-0/1?ff3=2&pub=5575376664&toolid=10044&campid=5338268676&customid=CjwKCAjwz6_8BRBkEiwA3p02VatC7sV5xoiH1QywW22d5z90c0gA5HJDj04loiIjHkKwgwJWuPRAjBoCwIoQAvD_BwE&lgeo=1&item=313228484671&srcrot=710-53481-19255-0&rvr_id=2647677270033&rvr_ts=3b28eacc1750a9b13ce7abcefedfcdc1&_mwBanner=1&_rdt=1&ul_noapp=true&pageci=a2aff2f5-423b-4cf3-954a-a98bfeb0d21e
 Door latch is the big metal piece on B pillar,
Post by: Doctor Gollum on 18 October 2020, 12:47:26
Or the actual lock mechanism...
Post by: biggriffin on 18 October 2020, 14:27:50
 Part no he quoted is solonoid :y
Post by: fudgee on 18 October 2020, 15:18:05
Sorry guys I completely ballsed that up.
I need the entire lock mechanism and also the solenoid that sits at the bottom of it.
Both are buggered
Post by: fudgee on 18 October 2020, 15:22:12
https://www.ebay.co.uk/itm/274503836666
This is not the correct one but you get the drift.
Post by: biggriffin on 18 October 2020, 16:05:55
Both are buggered
 Probably find it's the solonoid, you need to find the problem,  is it when remote is pressed door doesn't lock, or can't be opened by using the handle
Post by: fudgee on 18 October 2020, 18:16:46
At first when you locked the car via the fob all 4 doors would lock and the drivers door would unlock again immediately.
This continued for about 6 weeks and then the drivers door would not close flush.
When you physically pushed it closed it just wasnt catching and securing on the latch.
I literally cannot drive it at the moment as the door swings open at any given moment so Im off the road because of this  :-\
Post by: biggriffin on 18 October 2020, 18:46:40
Sounds like you need the locking mechanism, not the solonoid.
Post by: biggriffin on 18 October 2020, 18:52:53
I've got 09174595. Think it's a rear.
Solonoid 90493703
Post by: fudgee on 19 October 2020, 00:02:42
Many thanks mate but I need a drivers side front unfortunately
Post by: johnnydog on 19 October 2020, 11:04:03
I may have a complete facelift front right hand latch mechanism, but no solenoid (motor). I will check today if that is any use to you.
Post by: fudgee on 19 October 2020, 11:59:53
That would be an absolute lifesaver if you have mate.
I can source a solenoid separately.
The main thing is being able to close the door properly because I literally cant drive it until I can do that
Post by: Nick W on 19 October 2020, 12:07:56
Have you tried moving the 'bear claw' part of the latch that actually engages on the staple on the bodywork? It's not unusual to find that they can get stuck in the closed position, and some manipulating can get them to work again. Copious amounts of solvent cleaner, then lubricant would be a good idea to reduce it reoccurring.
If the latch is loose and not locking into place, then you will need to replace the whole mechanism.
The solenoid continually operating could be the internal microswitch at fault - the forum favourite - or a short in the door wiring loom which was what was actually wrong with mine.
Post by: omegod on 19 October 2020, 18:20:25
PM'd
Post by: johnnydog on 19 October 2020, 19:11:38
I have now found my spare drivers door catch mechanism. I removed it from the original door on my 2001 Elite when I fitted a used complete replacement driver door.
If it is of interest to you, please pm me.
Post by: fudgee on 20 October 2020, 15:12:14
I managed to source a replacement mechanism which also has the attached solenoid so I am thankfully now sorted.
Many thanks for your time and effort its greatly appreciated  :y
Post by: johnnydog on 20 October 2020, 16:21:43
No problem. Glad you are now sorted.
