Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 01 September 2008, 02:31:11
Just thought I would do annother speed test, 2:30am my last post was no higher than 5700 KB/s
(http://www.speedtest.net/result/316516822.png) (http://www.speedtest.net)
heres mine (http://www.speedtest.net/result/316591419.png) (http://www.speedtest.net)
07:45 mobile data card
Virgin Media
(http://www.speedtest.net/result/316599123.png) (http://www.speedtest.net)
(http://www.speedtest.net/result/316628622.png) (http://www.speedtest.net)
Mines not good today. Meant to be 10Meg
(http://www.speedtest.net/result/316628920.png) (http://www.speedtest.net)
Vodaphone 3G Data Card 10.06 am
BUT
With a '3' 3G data card, same laptop, same position for the dongle, 3 mins later, the results are:-
(http://www.speedtest.net/result/316631015.png) (http://www.speedtest.net)
My current connection
(http://www.speedtest.net/result/316634304.png)
(http://www.speedtest.net/result/316635160.png)
my speed
(http://www.speedtest.net/result/316635677.png) (http://www.speedtest.net)
and i'm gratefull!
URL=http://www.speedtest.net][IMG]htt
ment to be 10 meg virgin ?? :(
(http://www.speedtest.net/result/316658520.png) (http://www.speedtest.net)
Thats works connection
FFS... thought i would be clever and test my home connection from work using Remote Desktop... However when I disabled the internal LAN, it killed the server!
FFS GRRR!!!
FFS GRRR!!!
Yes, looks like you just got your ADSL connection from it.
I tried RDP, but it was abysmally bad - something like 2M down, 1M up.
I will have to do from office tomorrow, if I go in.
Then, to be really clever, I though about doing it from one of the News servers - 1Gb of unfettled connection, straight on the Colossus backbone, but probably a bit naughty ::)
(http://www.speedtest.net/result/316667237.png) (http://www.speedtest.net)
This is mine..........dont mean much to me tho :-[
As an ADSL connection, thats not too bad, up is a little low, but not awful :)
You HAVE to test it out ;D
I need to find a way of making my server ALWAYS connected to the internet. If anyone knows how, let me know! (windows 2003 server btw, with a usb ADSL modem). Any ideas??
The plan was to disconect the LAN as my sister will prob be using her pc on the internet! (or at least she was! ;D)
God knows why, but its disconnected from the web too?
Just notice my avatar has now gone too! DUHH! :'(
RRAS on Windows Server will do the always connect to internet, though to be perfectly honest, get a router.
Yes, thats what I need to sort, however every time ive tried its all gone tits up!
RRAS is fairly easy to set up, you'll have to set up as NAT though, as it can't deal with addressless routed IP, as is used if you have a block of RIPE IPs
(http://www.speedtest.net/result/316797576.png) (http://www.speedtest.net)
Quick enough for me. :y
Blimey, whats that... ...up looks like dial up, down looks like a poorly 256k line
Edit, just seen, 3G. Still too slow, guessing its actually GPRS :-/
(http://www.speedtest.net/result/316852928.png) (http://www.speedtest.net)(http://www.speedtest.net/result/316854533.png) (http://www.speedtest.net)
I DID 2 AND A BIT OF DIFFERENCE IN DOWNLOAD??
WHAT ALL THIS MEAN LOL
(http://www.speedtest.net/result/316857510.png) (http://www.speedtest.net)
I do remember zen giving me the option of 1 static IP, or 8 IP's for NAT maybe???
Heres my results (prob the slowest on here for home broadband!)
(http://www.speedtest.net/result/316857428.png) (http://www.speedtest.net)
Home:
(http://www.speedtest.net/result/316857590.png)
(http://www.speedtest.net/result/316858364.png)
Variations are expected, both adsl and cable users. Cable can be particularly affected by other cable customer's habits. DSL tends to slow up a bit during peak times.
that is number of RIPEs they offer you.
You speed is rubbish, or are you on a 256k line?
Home:
Jeez. I take it when you move, you'll use a different service provider ;D
HSDPA what ever that means.... ;D
Its quite misleading actually...apart from a couple of sites Betfair and Ebay it loads the content plenty quick enough,no lag or delay.
My home broadband is ofcourse quicker but not THAT much more noticable. :-?
Home:
Yep!
Note the choice of remote servers!
High Speed Downlink Packet Access.
Its a method for packet distribution over 3G networks using HARQ and can support upto 42M using the newer plus version.
It can also be rolled out onto most existing 3G base staions without hardware upgrades and will be what finally does for the ill conceived wimax!
I find the broadband latency is worse than it was with ISDN
Generally not much in it, but ISDN is point to point straight to ISP, DSL can go round the houses to get to ISP, so you can be unlucky depending on the combination of where you live and what ISP you pick.
Rubbish at work at the moment
If its that bad, have a chat to your isp...
You will only notice latency on interactive comms like VoIP (which is shite anyway as its a low priority service).
No real affect on downloads etc.
I use VoIP a fair bit at home, giving it a fairly high QoS priority. My ISP does not traffic shape. Works well for me :y
here's mine....
(http://www.speedtest.net/result/316925747.png) (http://www.speedtest.net)
i thought it was running a little slow today, this proved that as well
I understood very little of that.... :-[
All i know is im told it should be faster come end of the year... :y
Thought I would do a retry at a more reasonable time. maidenhead not showing so I used London then Paris.
Speeds are holding up well.
(http://www.speedtest.net/result/316930357.png) (http://www.speedtest.net)
(http://www.speedtest.net/result/316930897.png) (http://www.speedtest.net)
Yes, Im on 256k :'(
(http://www.speedtest.net/result/316942422.png) (http://www.speedtest.net)
reasonable :-/
Just done another test,could not get london at all this am.
(http://www.speedtest.net/result/316945411.png) (http://www.speedtest.net)
(http://www.speedtest.net/result/316995948.png) (http://www.speedtest.net)
(http://www.speedtest.net/result/316997122.png) (http://www.speedtest.net)
Within two minutes of one another using my o2 wireless "dongle" (I love that word :))
I suppose I should be happy seeing as I'm in the middle of nowhere in the west of Ireland ;D
Thumbs up to Plusnet, they tell me I have a 6.5Mb account/connection, and BT seem to be on he ball
(http://www.speedtest.net/result/317004322.png) (http://www.speedtest.net)
As I came in the office today, thought I'd run one from my desk...
(http://www.speedtest.net/result/317064689.png) (http://www.speedtest.net)
Still not brave enough to run one from one of our unfettled internet feeds :-/
(http://www.speedtest.net/result/317077163.png) (http://www.speedtest.net)
Now thats more like it.
lol, the limit in reality at the moment is the link from the base station to the network which is often only a few 2M streams!
The technology is quite simple, because they know there will be errors in the sent packets, they actually transmit each packet a minimum of three times but encoded using 3 different formats. At the far end (or your phone depending which direction the data is traveling in) the packet is decoded and then compared to the others in order to error correct.
(http://www.speedtest.net/result/317095809.png)
Used to be a lot quicker when we first went BB
(http://www.speedtest.net/result/317118102.png) (http://www.speedtest.net)
Vodafone HSDPA Data Card, So much for there advertised 7.2 Mbs,
Where do all the previous tests come from?, theres loads and mine go back to 2007!!
Having tested a few data cards the performance of HSDPA devices varies greatly IME, and the advertised data rates assume a perfect RF signal path. Levels perfect, no multipath, etc. In other words, if you want a solid 7.2 Mb/s, ask Vodafone if you can run a bit of coax to the local node-b. ;D
(http://www.speedtest.net/result/317304891.png) (http://www.speedtest.net)
not too bad considering time of day
(http://www.speedtest.net/result/317307679.png)
BT Total Broadband but at a bad time of the day in the South East! ::) ::)
from home :P
(http://www.speedtest.net/result/317307828.png) (http://www.speedtest.net)
(http://www.speedtest.net/result/317453264.png) (http://www.speedtest.net)
vodafone 3g card, hanging out of the window of a B&B in hull, on a 3m usb cable. :D
I hate working away from home.
just looking at this, seeing as ethernet performance plummets at 40% (or did in old days), thats pretty much max I'll get when connected to 100Mb switch? Or is the fact its switched now going to improve how well it performs under heavy utilisation?
Again, its dependent on what is set up on the network with respect to links and ques!
A switch in threory should give you full output bandwidth if nobody else is using any of the other leaf ports.
As I typed it, I seemed to remember I was going back to the hub days....
The office was fairly quiet at the time, I know we have 100Mbit link out to main corporate network, and about 15 hops to get to internet!
(http://www.speedtest.net/result/317741509.png) (http://www.speedtest.net).... :-/
(http://www.speedtest.net/result/317759684.png) (http://www.speedtest.net)
