Omega Help Area => Omega Electrical and Audio Help => Topic started by: countrywoman on 14 December 2020, 10:56:51
Spent hours trying to work out the switch panel order from Haynes manual , GGGGRRRRRRRRRRRRR. great when you follow the track numbers and then in next diagram there is nothing there. TBH only using hazard and abs and repurposing heated rear window switch . From my own working out the heated window is to the left of hazard and traction control is the only one with a black wire with red trace . Only other switches I have are dome light and recirculating air anyway and not needing them as the loom is going in my Austin hot rod. Its an 85 ex police estate that is the donner .
Picture of dash in manual is so poor and looks like later model as TC switch is below and to the left that it was no help so if anyone can tell me switch order thanks. Will have to get a strong magnifying glass I recon!!
'85 ???
If the donor had the grill in the bonnet, it's a face lift car... Haynes is only a rough guide for these...
'93-'96.5 is pre facelift, '97-'99.5 mid facelift is what Haynes refers to as "later" models. Facelift 2.5/3.0 is basically the same as the mid facelift, but some of the wire colours are different.
Pre face lift, its mostly correct and following it fine . Will be stripping out a lot of unused wires . There will be more questions to come no doubt.
