Omega Help Area => Omega General Help => Topic started by: Phil.xp on 01 June 2021, 23:36:37
Title: 2.2DTi Fuel Filter Clip
Post by: Phil.xp on 01 June 2021, 23:36:37
Hello all, just a quick one.
Does anyone have a part number or perhaps a link to the clip for the “OUT” (return) metal fuel line coming out of the fuel filter?
Many thanks,
Phil
Title: Re: 2.2DTi Fuel Filter Clip
Post by: Enceladus on 02 June 2021, 12:58:50
Is it number 14 on this (https://vauxhall.7zap.com/en/car/v94/g/0/13-1/) drawing?
In which case you might need a special tool or pliers to fit it. Would a Jubilee clip fit? Or a local motor factor should have some sort of suitable fuel line clamp?
Post by: Phil.xp on 02 June 2021, 19:11:49
I did look at that drawing before and thought it was but it’s not. It’s on the “out” hard metal line coming from the fuel filter and it’s the same type of clip used with other Vauxhall’s were you press two tabs at the same time to release it.
It’s a much bigger version of the clip for this that I can’t find it anywhere and places I’ve contacted don’t have them.
