Omega Help Area => Omega General Help => Topic started by: robson on 08 August 2021, 22:51:18
Title: Lights flashing
Post by: robson on 08 August 2021, 22:51:18
car locked doors and windows shut indicators flashing, unlocked door flashing stopped locked up and flashing again. unlocked flashing stopped locked up and now appears to be back to normal only time will tell, Any ideas..
Title: Re: Lights flashing
Post by: robson on 08 August 2021, 23:49:02
Lights flashing again disconnected battery gone to bed
Post by: Doctor Gollum on 08 August 2021, 23:58:47
The alarm is going off.
Start with the bonnet switch.
Post by: robson on 09 August 2021, 09:43:58
Thanks DG I will look at that,  the alarm is not sounding just the lights flashing could it be the alarm is dead therefore just flashing lights?
Post by: robson on 09 August 2021, 09:54:04
I should have said is the horn dead? not the alarm.
Post by: Doctor Gollum on 09 August 2021, 10:53:54
Has the power sounder been removed? Alarm horn, if fitted, is next to the power sounder.  ;)
Post by: Andy H on 09 August 2021, 11:11:42
The alarm horn died on my 2.6 so it didn't make any noise when the alarm was triggered (at least not after I took the power sounder out)
I did buy a new alarm horn and a new power sounder but never got around to fitting them  ::)
I assume that you have already removed the self immolating power sounder? that has a habit of triggering the alarm just before starting the fire........
Post by: robson on 09 August 2021, 11:34:46
I am fairly sure that I removed power sounder although that might have been on my previous omega.I will have to check if it has been removed. Have read a few posts on removal what is the best way to check if it has been removed.
Post by: STEMO on 09 August 2021, 12:41:07
Lift up the scuttle passenger side and have a peek in there. They're not difficult to find.
Post by: Andy B on 09 August 2021, 13:34:32
isn't it on the driver's side?  ???
Post by: STEMO on 09 August 2021, 14:13:24
Ermmmm......yes. Silly me, been a while  :-[
Post by: Andy B on 09 August 2021, 14:25:26
it has been for most of us here .....  ;D ;D
Post by: robson on 09 August 2021, 16:03:34
I took the rubber drain grommet out of the scuttle cover and had a look in, I saw the horn but no powersounder I must have removed it.Does it attach to the bracket which is just below and to one side of the scuttle drain grommet. I also thought I could see a tapped up cable.Whilst in there I noticed a lot of crud in the base is there a large drain down there or does it need cleaning like the passenger side drain.Checked the bonnet connecting plug which looks ok.The car has stood idle for some time and when started it was a bit sluggish.could a low battery give this problem.All seems ok at present but will charge battery anyway.I always disconnect both negative and positive when connect my battery conditioner is this necessary.
Post by: Andy B on 09 August 2021, 16:42:51
It's not whether the bonnet switch is plugged in or not, it's the bracket that gets bent over so no longer makes  proper contact with bonnet  .... unplugging it is the same as the switch  being in the correct position.
Post by: robson on 09 August 2021, 19:25:14
Yes Andy I checked the switch support etc.but difficult to check the operation with the bonnet closed Obviously needs a meter connected
Post by: Doctor Gollum on 09 August 2021, 19:32:53
A dab of grease would tell you if it's touching the bonnet or not.
Even Ketchup would suffice...
Post by: Migv6 le Frog Fan on 09 August 2021, 19:53:50
Or blu tack ,chewing gum etc. etc.
Post by: Andy B on 09 August 2021, 20:18:27
so, if you unplug it and the alarm doesn't sound, the bracket just needs adjusting .... upright is normally good enough
Post by: robson on 11 August 2021, 09:08:12
I charged the battery up and all now seems ok. :y
