		Chat Area => General Car Chat => Topic started by: Raeturbo on 09 August 2021, 14:06:39
				https://www.ebay.co.uk/itm/234079680875?fits=Plat_Gen%3AB%7CModel%3AOmega&hash=item36803c796b:g:7FoAAOSwi0lg5SeR
 I’ve read some of the aftermarket ones are useless any used these?
				It will be fine ;)
 Even if it only lasts a couple of years, it's cheap enough to be considered a service item...
				One problem I discovered many years back on a Carlton arm that had been replaced with a non gm one was that it was ever so slightly shorter in length ( bush length) so that when fitted and the nut was tightened to its stop it was still loose on the bracket.
 It was rectified at the time with a suitable washer that went over the raised non threaded part of the shaft and made it tighten to its correct stiffness. This arm lasted at least 5 years to my knowledge afterwards.
 Just a point to note when fitting l
				Thanks👍
				It will be fine ;)
 Couple of years?
 That may be enough to outlast old Rae. ;D
				Watch it mate⚔️
