Omega Help Area => Omega General Help => Topic started by: addy on 18 September 2021, 13:16:26
Title: 2.6 omega bolts, that hold brake claliper cradle on.
Post by: addy on 18 September 2021, 13:16:26
Hi
Would anyone know, the code for the large bolts that hold, the brake cradle onto the steering knuckle not the slider ones, or even know where I can get them?. The start of my VIN is :- W0L0VBM. I have included a photo, showing the piece I need the two bolts for.
(https://i.postimg.cc/XvNpkY6Z/brake1a.jpg)
Thank you in advance for any help.
Addy
Title: Re: 2.6 omega bolts, that hold brake claliper cradle on.
Post by: GastronomicKleptomaniac on 18 September 2021, 13:20:58
I've had a look and can't find any in my box of spares.
If the old ones are still in one piece then pop down to an engineering shop and ask them to match - theres a couple near us we've used in the past :y
Post by: addy on 18 September 2021, 13:28:00
Thanks GastronomicKleptomaniac
Having great fun, taking the front driver side bits apart, just to remove the control arm. The brake bolt heads are rusty as anything, so had to tap a slightly smaller socket on, luckily they came out. One of the sliders has stuck in the caliper so wil be doing them again, even though were done, when shocks were done. Just fighting with the control arm, to steering knuckle ball joint bolt. Was thinking of getting new complete calipers as I did on Mags car.
Catch up with you soon
Addy
Post by: LC0112G on 18 September 2021, 20:16:16
EPC says VX90541296, OP-5-43-218, M12x40. It doesn't specify the pitch, and I suspect they're metric fine. They're also probably 8.8 High Tensile, but you'll need to look at the heads to know for sure.
Post by: Nick W on 19 September 2021, 01:21:04
if the pitch isn't specified it ought to be metric coarse, which is 1.75mm for M12. But cars are littered with M12x1.5 ptich threads, which is a bit of an oddball
