Omega Help Area => Omega General Help => Topic started by: iansoutham on 07 November 2021, 07:44:29
Has anyone had issues with X20XEV aux belt tensioners losing their tension?
Reason for asking is that I have randomly seen the battery light on full at night intermittently but yesterday drove to Wales and back from Kent and the return journey was in the dark. The light kept changing in luminescence depending on load, wipers, indicators, etc and when the light wa a brighter I thought that maybe I could smell something but at 70mph you won’t hear a belt squealing.
I tried a few things and when I reduced the load by turning the aircon off, the light went out completely after about 5 seconds and stayed out until you turned the aircon back on. This would bring the battery light on about half brightness and then drop down, I suspect as the belt slipped and caught back up with the load.
I am going to check the belt today and probably change it during the week, but was also thinking about the actual tensioner and if it could be the main reason?
Quick update, have been out to the car and all pulleys spin freely, alternator, aircon (and actual pump part, but just free-wheeling pulley). Aux tension set pulley sounds like the bearing is a little dry but no free-play. The belt has been slipping, there is no dust but the rib teeth are “shiny”.
Is there a minimum force setting for the tensioner?
Your barking up the wrong tree.
Start with the alternator/battery. Run through Kevin Woods' starting and charging tests and fix whatever is actually broken. :y
Should have said (as I knew the at would be the 1st thing someone would say), did that the other month when initially looking for the problem. All good.
Try a new belt first just could be stretched /worn out maybe. Put everything on and listen for squealing under the bonnet. Check Earth. Could be brushes in the alternator?
The charge light on my Omega used to glow faintly, and got slightly brighter when rev'd. I crimped the positive battery cable clamp a nudges tighter and it sorted it.
A worn or stretched belt would soon get thrown and it would squeal and slap like a stuck pig in the meantime.
The belt is a service item, so should be changed if history is unknown, but it isn't the issue.
On that I do completely agree, it may be a victim of another problem but there was still tension on the belt. Been out for a drive and when hot, the tensioner pulley bearing is not in a good way and feels a little bit rough so definitely needs changing anyway. I will try to find one of my digital torque wrenches and see what torque figure it takes to make it move for reference.
I used to build alternators and starter motors at a previous job and have a “jig” for testing so I know alternator is okay from previous test when looking for the fault prior.
Out of due diligence, I will double-check wiring losses though…
Kevin's test covers the battery terminals, but most simply do the engine on/off voltages.
New pulley is about a tenner, even for a GM one.
The bearings can usually be repacked, but the plastic pulley will deteriorate quickly if it gets hot.
If it has a separate idler, I can't honestly recall on the four pots, then belts and braces would swap that too :y
Latest details:
Aux tensioner pulley was bone dry so removed the seal and regreased properly.
Battery figures are below
Resting charge 12.62V
Resting charge with Lights on 12.2V, returning to 12.6V after turning off
Idle charge 14.2V, electrics off
Fast idle charge 14.3V electrics off
Idle charge heating on, no a/c 14.15V
Idle charge heating on, a/c on 14.0V
Idle charge heater, lights, rear window 13.45V
Fast idle charge heater, lights, rear window
13.5V
Idle charge all electrics (everything you could possibly switch on) 12.4V
Fast idle charge all electrics 13.3V
Wiring check battery to alternator
14.05V at alternator
13.6V at battery
16.71 lbft torque to lift tensioner arm
Fast idle voltages are low and your dropping half a volt to the battery. The cable is only two feet long, so that's going somewhere.
Only update today is that the light came on dimly 1st thing this morning and then went out after a couple of minutes, not to return all the way to work.
Will check again the evening on way home.
Too soon to say really…
as mentioned above somewhere,a voltage drop of that amount on a short cable ( of possibly 6 or 10 mm/2 )would suggest a bad or failing lug crimp joint so id be recrimping them first and making sure their connections in the fuse box on the battery terminal is all good.you could also prove it by hooking up another cable too to see if the volt drop virtually dissapears.
otherwise an occasional charge light can come from low brushes ( this would progressively get worse)or a bad diode or diode joint.i think they are just crimped rather than joined properly ?
my moneys on the cable crimping thou .( main starter cable worth checking too as those can work loose over time.)
Most likely suspect for me, probably at battery end as those joints are normally alloy connectors.
I do have a way of testing the cables, but it is a 2 person job really using the “jig” I have for alternator testing.
When doing the tests, the cable and connections all stayed cool, even under load so may be internal wiring corrosion somewhere, or something completely different..
Bench testing any single component doesn't give a full picture... A weak bench pass won't it in situ if there's a combination of things going on.
I’m with brushes👍
Have tested the lead by basically disconnecting both ends and applying copious amounts of current through it. Although not loose, the battery end did get “warm” so I would say something there for definite. It seems to be that the light comes on dull for a few minutes after start up before slowly going out unless lots of equipment turned on.
The light is a charging light not a battery light.
A reduced amperage means an increased resistance for a given voltage... V=IR and all that jazz.
Update…
It is definitely NOT anything alternator related.
I swapped the alternator out for another known good one (borrowed off a friend who has an X20XEV Cavalier that had literally just come home from work in it) and still doing exactly the same thing. I will bench test my original again, just to be belt and braces. I did put a regulator pack in it about a year ago.
I also put a jump lead from the alternator B+ to the battery directly (with the original lead still attached) and again, no difference.
I will take the car into work this weekend and deep charge the battery off the car and then use our warranty-spec battery tester to get a “real world” condition report (full computerised that we have to have for our warranty claims to BMW) on that as well.
Bad earth?
Bad earth?
Can only double-check.
This light has been random for a couple of years and many things have been apart and rebuilt in the meantime so I would like to think not?
Quick question as I have not looked too far at it at the moment, the positive lead runs from the battery, across the top front of the engine and down in front of the alternator. It then splits to the alternator and the starter motor. What is the split? Soldered connection, runs from starter motor to alternator as a separate lead, other?
It's two separate leads in a common wrap if it's anything like the V6. Which it sounds like as the routing is pretty much identical. :y
Definitely 1x larger lead off the battery terminal than what is at the alternator. I know onFords they run a lead to the starter and then a separate one from that to the alternator, just hard to take it a part in the dark at the end of a driveway.
if you have tried a lead from the alternator direct to the battery (battery rather than anything else)then you have already eliminated anything positive cable wise so its either a bad earth connection ,a short somewhere on the charge light lead or a fault on the dash.
especially if you dont actually have any charging issues or obvious faults.
i would have thought due to the volt drop alternator to battery then adding the extra cable would have shown up the cable or connections but apparently not.
Well…..
Alternator double-checked and all good. All positive leads I can get to cleaned up. It would appear that the X20XEV runs a cable to the starter motor and then a drip lead back to the alternator. The starter motor connection is the only one I have not managed on the positive side.
On the earth, it goes straight from the battery to the bracket behind the PAS pump that holds the aircon pipe. The “stud” looks like it may be the culprit as someone (not me) has had it apart and then done it up allowing the connection to twist right round and bend. All removed, earth connection cleaned up and straightened, along with the stud getting a drop of thread lock to hold it in place (it turned instead of the earth but when trying to undo) and everything reconnected after cleaning.
Whole 0.2V drop now from alternator to battery, no battery light at the moment and only glows slightly with aircon, headlamps, front and rear fogs, heated rear window and both heated seats on, then goes out as soon as heated seats switched off.
Will find out tomorrow for certain. Will also take starter connection apart Saturday when I take car into work to do oil change on the ramps and charge/test battery as access is only from underneath.
