Omega Help Area => Omega General Help => Topic started by: polilara on 16 November 2021, 19:08:56
Title: Disconnecting Seat Belt Tighteners
Post by: polilara on 16 November 2021, 19:08:56
I am going to change my worn textile seats to pretty good leather ones. Face Lift 2001 Saloon both. Saw in this
http://www.omegaowners.com/forum/index.php?topic=90569.0
that tighteners are mounted to the seats. Do I have to pay attention to something when disconnecting them. Do I have to use my original tighteners or does the car recognize the new ones?
Title: Re: Disconnecting Seat Belt Tighteners
Post by: Doctor Gollum on 16 November 2021, 20:30:48
Face lift to face lift is fine  :y
Only caveat if your current driver seat is manual with no memory and the new seats have memory... You will require  longer bolts for the driver seat.
Post by: polilara on 17 November 2021, 16:42:59
Thanks DG
Present seats in front have both electrical height control while other movements etc. are manual. New seats have more electricity. That is all I know. Just to confirm the tightener question. I am talking about the item you fasten the seat belt into. It is a safety thing like airbag. Did you mean that, too? If I disconnect tightener from its pug and connect it back later do I need Tech2 or anything else to get the car to accept it. Can I use the tighteners coming with new seats and connect them without the need to use any code reader instruments.
Post by: STEMO on 17 November 2021, 17:05:58
If you mean the seat belt pretensioner, there are various vids on it. Here is one:
https://youtu.be/IGJGlnj8w_s
Post by: Doctor Gollum on 17 November 2021, 18:29:07
Thanks DG
Something lost in translation...
Pretensioner and side airbags same across all face lift seats.
What does more electricity mean?
Post by: polilara on 18 November 2021, 11:02:17
More electricity means what I heard from the seller: The driver's seat is moving with motors front and back+some other movements perhaps Backrest etc. electrically, do not know. Have to visit him and check. Whatever it is they are leather and in good condition. If swapping from FL to FL is ok then all ok.
Post by: Doctor Gollum on 18 November 2021, 11:55:55
Right. You have standard seats. The new seats have memory/full adjustment. Ergo you need the longer bolts for the driver seat.
Electrically, you need to follow the guide.
Airbag/pretensioner, all is OK.
Obviously, it goes without saying that best practice is to disconnect the battery for 30 mins to discharge the airbag capacitors before unplugging anything. ;)
Post by: STEMO on 18 November 2021, 12:22:13
Where's the fun in that?
Post by: Doctor Gollum on 18 November 2021, 12:37:06
I know,  ;D but one day some snowflake will smack himself on the bonce and blame everyone else...   ::)
Post by: polilara on 18 November 2021, 15:29:11
OK, found it, nice, really nice. I solder together those mentioned and both end of each wire should still be connected there where they are now located?
http://www.omegaowners.com/forum/index.php?topic=90680.0
Post by: polilara on 18 December 2021, 16:07:54
So seats changed. My originals did not have memory and these new either.
(https://i.postimg.cc/4d3M8b73/20211217-191535-1.jpg)
(https://i.postimg.cc/Nfht0S27/20211217-191628-1.jpg)
I'm happy, like new.
Referring to this:
https://www.omegaowners.com/forum/index.php?topic=149020.0
I am not sure what the material is. Feels more leatherette. They are original seats from FL 2001 which I have, too. Perhaps center parts real leather?
Referring to this:
I did not do any soldering yet as I did not understand the text well enough. At least all the movements work like tilting the seat, back rest and moving front/back. The connectors were similar so just plugged... Heating not yet tested, could that be the problem or why this soldering? Below fig of connectors of my original drivers seat. Do "Elite Seats" differ from these?
(https://i.postimg.cc/1RFG6V4h/20211218-141710-1.jpg)
And last comment: Both driver side and passenger side required longer bolts.
Post by: Doctor Gollum on 18 December 2021, 17:39:32
The soldering is to bypass the mirror position memories as cars built without memory seats use different mirror wiring. AIUI ;) if the seats are working fine, then I wouldn't worry about the soldering.  ;) (that may be a specification difference between UK and Euro cars...)
JOB well jobbed 8)
