Chat Area => General Car Chat => Topic started by: john1959 on 01 December 2021, 18:26:09
i filled up 10 days ago at sainsburys e5 soon as i went down the road could smell fumes like bit petrolly had the smell till i topped up 50 quid at a jet garage smell disappearde but now car not firing as usual and the revs when idling go up and down like itll cut out no cut out yet but needs 2 or 3 times starting it ever since i had that lousy fuel from sainsburys.maybe caused problems with the mixture.im lost never had this prob before.
Have you checked fault codes ?
make sure there are NO petrol leaks (tank connection can rust apparently )
and check there is no oil or water in the plug wells
Vauxhalls do overfuel when cold too
i checked all that dave no leaks or oil in plugs its just the crap fuel i got started the smell now smell gone and revs up and down never was before no lights on.thanx
This happened to my 3.2 when Asda had contaminated fuel some years back (they at least admitted it). It was one of only two times that my emission light came on. It was like it for about three days until I could get half a tank of V Power in it. It cleared on its own in my case so I can't help with a remedy I'm afraid. :-\
I should have added to this, the contaminated fuel upsets the lambda reading. In my case it cleared itself after filling up with decent fuel and a couple of spankings to give it a clear out. :y
Since September, I've only filled the 3.2 Omegas with 99 Tesco Momentum or Esso Synergy Plus - none of this E10 crap....
They have never run as well. More responsive and better mpg. Worth the few extra pence to fill up, certainly in my book. The extra cost is worth it for a car that is running 110% and the noticeable difference in driving pleasure.
thanx johnny dog thats exactly the same as me only e5 from jet made a mistake going to sainsburys for e5 theres no other reason the car had these issues just crap petrol
More likely to be contamination in a forecourt tank than specifically due to E10.
Also, when did you last get the fuel filter changed? Not recently I will wager.
Some injector cleaner and a fresh filter would be prudent. And avoid that forecourt for a month.
Usually, in cases of fuel contamination on any particular garage forecourt, other cars will have been affected, and this circulates like wildfire on Faceache and the like.
Making a claim against the garage is difficult as a friend of mine found out in a similar situation - especially if time has elapsed since filling up at the 'suspect' garage. It involved fuel samples etc, although his car was so badly affected with water in the fuel that it conked out after only a few miles and had to be taken to a garage to be sorted, which was also necessary in his pursing the claim, whether through his insurance or otherwise. That was an extreme case of fuel contamination though....
Fortunately in an Omega, it doesn't take long to burn through enough to top off with proper fuel.
It won't help that many garages were run dry, so if you were unlucky enough to be one of the last few, then you'll have gotten more than your fair share of crud and water.
Generally speaking, there's a minimum fuel quality and cars are tuned to allow for a degree of variation. So it's pretty rare to get fuel dirty enough to notice.
Changing the filter helps mitigate any subsequent problems. :y
then you'll have gotten more ....
::) ::) ::) Ya'll have a nice day!! ::)
What word would you have used? ::)
Got doesn't quite seem adequate...
In British English, the past participle of the verb get is got. In American English, people say gotten. ** Note that have got is commonly used in both British and American English to speak about possession or necessity. have gotten is not correct here.
No one has yet pointed it out, but do you mean you filled up with E5?
If so I recommend you do not as E10 is suitable for our 3.2's, and mine has run perfectly on it since it first came on the market. ;)
Why ever notten?
Scaremongering rubbish.
E5 and E10 are both perfectly fine in most everything, including all Omegas.
got would have perfectly adequate .... :y
:y :y
Eh? What are you on about again? ::) ::)
There is a difference between the two fuels, as I think John has found out.
What it is you failed to notice that John had posted "e5" and if he uses E10 then he will find all will be ok.
Oh, yes I use Sainsbury's all the time as I have done for decades and no doubt due to their huge turnover of fuel none of it has ever given me any problems. Obviously it is always possible to find contaminated fuel, but I recommend John just uses E10 before going through the work of checking anything else on his car. We all should know that often it is the simple answers that meet our challenges!
His complaint was contaminated fuel. The type of fuel was irrelevant as his complaint would have been equally valid if he had filled a diesel generator with a batch of contaminated red diesel.
E10 is the newfangled muck that everyone is whining about, E5 is what we have been buying for years.
So again, all scaremongering rubbish.
Especially as he hasn't bothered responding to his previous post on the subject...
https://www.omegaowners.com/forum/index.php?topic=148926.0
:y :y
Ah, I have got it now... I'd gone and gotten all confused ;D
This forum uses an American spell checker I think
so big words like "got" might get confused :P :D :-X
OK DG, I understand that. :y
But with both posts he assumes his fuel is contaminated, without proof just circumstantial evidence. His problems also seem to have continued, despite using other petrol which suggests it could well be another issue.
As for E5, I have not bought super-unleaded for two decades, not since trading in my Senator. I have used the near equivalent of E10, in other words standard unleaded, in all my 3.0's and 3.2 without any issue. ;)
I use E5 super ,often from Sainsburys as it's convenient.
you could get a bad tank of fuel from anywhere ,pot luck really regardless of what it is E5 , E10 , diesel , biodiesel
just like that cheap electric that don't brown your toast enough ::)
Wot dat den? :-\
Wot dat den? :-\
Someone elses :D
like mr jonnydog above im only using esso synergy 99 in allmine now and if i ever see any E5 id use that ( as said weve been using E5 for years anyway but E10 ? not sure realy )
My last three tanks have been Shell V Power, but that's to try and help the emissions rather than the ethanol percentage.
The Barge doesn't appreciate it though... No improvement of MPG which is contrary to previous experience with V Power, although it has coincided with the drop in temperatures.
