Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: Mutha Jugs n Speed on 18 December 2021, 13:01:58
Shot in the dark this one.......looking for the EGR five pin plug and a length of loom to go with it......this is for a 2000 facelift 3.0. tia :)
Same plug on many Vauxhalls of that era ,astra G ,Zafira A ,Corsa c etc which will expand your search options
Deleting the EGR is obviously not cricket :-X ::) :D
Many thanks for the info, 3.2 manifolds ;)
Just cable tie the egr valve and wiring up out the way.. Will look on what I've got left on the estate when I get home, no promises.
Or you could make one of THESE (https://rlw7w.uk/engineswap/egrdelete/)which is much more compact.
Thanks BG, also I've managed to find a pre wired connector made of Chinese cheese, which 'should be' the answer to the problem ??? only got to splice it in :-X Nicks solution much more viable, as where the EGR was hidden has actually over time damaged the wiring.
Nope.. It went with the engine looms .
Cheers Trevor, the Chinese connector is due in a day or two now, have since found the same one on ebay, but at six times the price of the first one :o
I built a device to fool the ECU which was similar to the link above (but not the same, as the wiring and valve is a bit different on the Omega)
