Chat Area => General Discussion Area => Topic started by: omegaV6CD on 07 December 2006, 10:59:34
Hi Guys,
jut a quick question, is the inlet manifold divider on the omega different from the 3.0 lt to the 2.5 lt engine?
if yes does anyone have any pictures?
THanks
Anyone??
it depends...
if both engines are the same age, then yes i think they are the same.
However if they are differnt ages, then they maybe differnt. Later 3.0's had a shorter inlet and extended plenum... this came in around 1998
it depends...
THanks for the reply but i'm not talking about the plenum, i refer to the manifold divider the black thing that sits between the cylinder head inlet ports and the intake manifold.
Bet Markjay has got some pictures...... ::)
Different...
FLANGE, INDUCTION MANIFOLD X25XE, Y26SE 90467003 8 49 441 1
FLANGE, INDUCTION MANIFOLD X30XE, Y32SE 90467004 8 49 442 1
Thats the black plastic bit with loads of bolts in....
THanks a lot for the info, i believe then that the 3lt one should have better flow characteristics, does anybody have one to go with my 3lt cams?
Well, when I compare the two I cant see any obvious differences.....the section with the injectors is different as the injectors are bigger.....
Right i see, i thought that the 3lt one had larger intake ports, if they are similar then there is no point messing about.
Thanks
