Chat Area => General Car Chat => Topic started by: GastronomicKleptomaniac on 01 April 2022, 20:42:39
Title: ACTUAL IMPORTANT ADVICE
Post by: GastronomicKleptomaniac on 01 April 2022, 20:42:39
***ACTUALLY IMPORTANT***
A few weeks ago I posted about how my grinder disc exploded and nearly took my head off. At the time I put it down to me being a cack handed moron (still true) or having used an older disc.
I've just opened a new box of cutting doscs that I bought from Aldi in recent weeks. The outer box says BBE May 23... But the discs wrapped up inside are BBE Sept 21 (!!!)
For the love of God if you have any Ferrex discs (or I'd imagine the same tyoe from Lidl as they stock similar in the aisle of unnecessary expense)... CHECK THE DATES. The thicker grinding and cutting doscs habe the same but I'm less worried about them doing an Oddjob on me.
Rest assured I've already contacted Aldi to make a fuss and hopefully issue a recall before some poor sod comes a cropper.
Title: Re: ACTUAL IMPORTANT ADVICE
Post by: dave the builder on 01 April 2022, 20:50:38
I didn't even know it was a thing  :-[
though i rarely use  carborundum cutting discs ,mostly diamond discs
Post by: biggriffin on 01 April 2022, 21:25:44
Cutting discs have a best before date :-[
I've got discs in my tool box,that are gawd knows how old .
Post by: STEMO on 01 April 2022, 21:47:13
I've used cutting discs from time to time, a good while ago now, but I had no idea about 'use by' dates. Perhaps this should be better publicised.
Post by: dave the builder on 01 April 2022, 21:53:59
Not just me then  :D
Ignorance is bliss  8)
Post by: Andy B on 01 April 2022, 22:01:02
I only know about dates on discs because of being told so at work, but I've discs at home that are that old there are no dates on them.
Post by: Raeturbo on 01 April 2022, 22:48:42
Me too, I thought they just lasted until they were worn out.
Post by: Migv6 le Frog Fan on 01 April 2022, 23:02:48
In my experience they do. Only problems I ever had , when I used to grind metal for a living, was when the speed rating of the disc was much lower than the tool it was mounted on.
Seen serious injuries caused by that, due to a very incompetent manager.
Post by: Nick W on 02 April 2022, 00:46:32
Ever seen a moron fit a 9" disc to a 5" grinder? There are better ways to get a manicure as it wears down to size. Although it will never have a suitable speed rating.
Post by: johnnydog on 03 April 2022, 16:50:18
If the cut item, usually metal, is not supported correctly, the cut will close up, resulting in the edges nipping the cutting disc; in the worse cases causing the disc to shatter and chunks fly off taking your head off. This also unnecessarily tightens the centre spindle lock making it virtually impossible to slacken even using a longer key, resulting in more brutal methods of removal and damage to the locking pin.
I don't know whether the method of storage has an aging effect on cutting discs, but I keep mine in a dry environment.
Didn't know about the 'use by' or 'best before' dates though.
I have always bought what I consider to be better quality / well known branded discs - 'cheap shop' discs for little money are false economy imho in both quality and durability. Cheap discs don't last two minutes.
Post by: omegod on 07 April 2022, 08:41:31
I've had a few discs pop on me through me being a pratt and not supporting what is being cut correctly , certainly gets the adrenaline going  :o
Post by: grifter on 18 April 2022, 17:10:06
Usually use Tyrolit cutting discs after a few of those cheapy ones popped on me. Yes I was wearing safety gogglies but was just wondering if a part of it had impaled itself in my jugular!
Post by: johnnydog on 19 April 2022, 16:43:25
Think you might have felt it if it had done ;D...
Post by: STEMO on 19 April 2022, 16:50:09
But maybe not for long  :)
