Omega Help Area => Omega General Help => Topic started by: countrywoman on 30 April 2022, 17:04:42
Title: rear calliper/ pad fitting kit Question.
Post by: countrywoman on 30 April 2022, 17:04:42
So got some pads and a fitting kit for the Austin , now the Omega doner was ex plod but there is only one set of rear pads listed in Apex book. They are quite loose side to side and pins and anti rattle are to narrow . Any chance it has vented rear callipers fitted as they are solid discs , ATE callipers on rear with 40 cast in.
Title: Re: rear calliper/ pad fitting kit Question.
Post by: Doctor Gollum on 30 April 2022, 17:19:59
That caliper must ONLY be fitted with a 20mm VENTED disc.
All Omegas use the same rear pad :y
40 refers to the piston diameter.
Incidentally, this caliper is unique to the Omega and requires a different fitting kit, the parts of which were only available from VX.
The differences are given in a post in one of the help sections. This is something not to be skimped or ignored as it Will result in total brake failure as the pad wear.
Basically the pistons extend enough to haemorrhage fluid.
There is also a chance that the non vented anti rattle clips can effectively lock the brakes off by jamming between the pads.
Post by: countrywoman on 30 April 2022, 17:31:16
Thats what I thought , cheers .
Post by: Doctor Gollum on 30 April 2022, 17:32:52
You cannot buy after market vented calipers for the Omega.
Your options now are:
1. fit non vented calipers, which are available, use solid rear discs and the freely available non vented fitting kit.
2. Used vented discs with the correct fittings.
3. Use a completely different caliper/disc/pad from say a five stud Cav C or Vectra B.
Post by: countrywoman on 30 April 2022, 17:36:08
Vented disc me thinks, have access to an Apex book so will check dimensions to make sure it will fit calliper.
Post by: Doctor Gollum on 30 April 2022, 17:40:53
286mm X 20 from memory.
Apec list, or certainly used to, a vented fitting kit. They lie, it isn't suitable for the Omega disc... The pins are too short and the spring clips are too narrow.
All Omegas use the same diameter rear discs.
Here's the post I meant.
https://www.omegaowners.com/forum/index.php?topic=127928.0#new
Post by: Nick W on 30 April 2022, 20:38:53
There are various DIY solutions to the vented disc parts not being available. On an Omega they're probably worth doing.
On your Austin, the easiest way of dealing with the problem is to source and fit calipers suitable for the solid discs as it doesn't need the questionable improvement the vented ones provide. That's especially true if it already has solid discs :y
Post by: countrywoman on 01 May 2022, 08:24:31
Cheapest will be to fit new discs , they are a bit ratty anyway . Have one correct size pin in my box of old brake bits !
Post by: Doctor Gollum on 01 May 2022, 09:33:11
The 2.6 /3.2 were vented because the TC works differently to the 2.5/3.0 equipped cars.
Late European cars had the option of ESP, but we had to make do with TC which hammers the rear pads during wheelslip.
To be sure that your current calipers are correct, they should have an 8mm insert between the two outer halves, might now resemble a rusty stripe.
The 40 suggests that they are for vented discs, but I have never worked on a prefaclift Plod car, so it could have had a hybrid caliper fitted ie non vented with the larger piston bore.
Basically, if that stripe is present, measure it carefully and add the figure to the 12mm disc. This will give you the correct disc thickness.
Again, fitting a vented caliper to a solid disc could well kill someone.
Post by: countrywoman on 01 May 2022, 16:14:53
Had a very careful look and measure , it is a solid disc set up as not much space for disc to run through calliper. Its just the fitting kit is rubbish, pins and spring short and the end that goes in the outside is way to small for the hole . Maybe its because it has the larger callipers , wonder if they are used on anything else?
Post by: Doctor Gollum on 01 May 2022, 16:57:07
Physically the caliper halves are the same size, the difference is the 8mm spacer and/or piston diameter.
As far as fitting goes, they are interchangeable with the appropriate disc.
Mintex also do a fitting kit, p/n in the link a couple of posts up :y
Post by: countrywoman on 02 May 2022, 08:52:20
Yes £7 and a bit on the bay, worth a try .
Post by: Enceladus on 03 May 2022, 02:54:46
Surely the vented caliper pistons are slightly larger than the pistons for non vented solid discs?
The rear calipers for 12mm thick solid discs have '40' cast into the piston housings.
Calipers for 20mm thick vented rear discs have '42' cast into the piston housings. So roughly 9% more surface area on the pistons.
These vented calipers also have the 8mm thick spacer between the two halves to allow for the extra 8mm thickness of the vented disc.
countrywoman says her calipers have 40 cast into the housings. 40 would indicate solid discs and standard fitting kit. Check and see if there is an an 8mm spacer sandwiched between the castings? No spacer would confirm solid discs.
What's the part number of the fitting kit you have? Assuming you have solid disc calipers it sounds to me that you have a Vectra B fitting kit which won't work.
Post by: Doctor Gollum on 03 May 2022, 08:26:58
I had forgotten that the 3.2 caliper had "42" stamped in them.  :-[
Everything else that Rae has mentioned stands, although I wonder if the calipers and discs that were fitted to this donor car were actually Omega ones to begin with :-\
Post by: countrywoman on 03 May 2022, 09:10:01
It is standard solid , just wrong / bad fitting kit that confused me plus the fact pads are a lot slimmer than the space they sit in . Think my brain was out of gear that day (old age/dyslexic !)
Post by: Doctor Gollum on 03 May 2022, 09:36:51
The new pads, whilst floating, shouldn't have much in the way of free space between them and the disc. A couple of mm either side until the pedal is first pressed, then there should be next to no play  :-\
Post by: Andy B on 03 May 2022, 11:07:32
I'm completely lost now on this thread .....  :-\ :-\ :-\ ??? ???
Post by: Doctor Gollum on 03 May 2022, 11:26:40
Original complaint was the pads being loose in the caliper.
Which they quite possibly would be if the wrong caliper/disc arrangement was being used.
Post by: Andy B on 03 May 2022, 11:45:41
I knew what you were thinking ie solid disc in a 3.2/2.6 caliper .... we saw it at York on Mike Dundee's car when the caliper was pi$$ed wet through with brake fluid because a numpty mech had fitted the wrong discs. The pistons were just about to make a bid for freedom. Fortunately Mike got there in one piece .... it could have been different.
Post by: countrywoman on 03 May 2022, 15:30:39
Turns out the numpty at factors ordered the wrong kit 310 instead of 315 . 310 is Vectra B ----------
Post by: Andy B on 03 May 2022, 15:43:37
the world is full of numpties!  ::)
Post by: STEMO on 03 May 2022, 15:57:39
As Enceladus said earlier in the thread.
Post by: countrywoman on 03 May 2022, 21:05:16
yup!
