Chat Area => General Discussion Area => Topic started by: Rangie on 27 June 2022, 08:44:33
The words slave & master in reference to car parts has been banned as some workers have found it offensive..😟
Now that is going too far down the woke line ::) ::) :D ;)
what are the new terms then? :-\
The word Surrogate is to be used in place of both.
Little bit and big bit?
Thats been common across a lot of industries for the past couple of years.
In the IT industry, we no longer use Master/Slave references in clusters, now its Primary Secondary. Whitelists and Blacklists no longer exist, if favour of Allow Lists and Deny Lists.
To start a rage about it now is 2 years too late.
Well we didn't get that memo ;D
Just been on a calling discusing the Master and Slave audio DSPs
It's never too late to expose total stupidity..😟
are we allowed the terms of male & female?
Presumably these are now out and in respectively...
No he’s right, better late than never, don’t be a pussy
Fuc&ing woke squad are taking over
He's not, he just sits in one every day. A big black one! ;D
Of course I wouldn’t know that👀👀🤣👍
As if😀🫵
I've neglected the big black pussy for days, and not spent any time in her.
:P
Only if you don't exclude the other 159 variants. :)
:P
My original XFR was a black pussy. Ultimate black I think. Bastard to keep clean but suitably demonic looking in the flesh. :)
the maddest JLR thing is that to remove the engine from a RR Sport(?), the body has to come off the chassis! ??? ???
10/12 bolts rather than dismantle the engine in situ :D
brake lines, electrickery loom, 2 poster lift .....
Who told you that?
Just checked the 494 procedure, no different to any other car, disconnect a load of bits and lift out the top (and thats the straight six)
Also checked the 320, again no different to any other or the 494
None are body off jobs :y
Looms will have multiplex plugs, and the brake lines can stay with the chassis. Just unbolt the master from the booster.
Watched my indi do one even he agrees in his words " it's a piece of piss & everything is accessible" The one he was working on was in for new turbos.
Who told you that?
I might have the wrong LR then ... hence the (?) ...
Who told you that?
Range Rover ....
https://www.youtube.com/watch?v=vSuTngCAoSQ&list=PLD84zAgh0k_gn1mIa5RPVl7ohSKc43B1F
Who told you that?
Presumably this is referring to the L320 RR Sport? IIRC these were basically an L319 (Disco 3) in a party frock and these too had a number of body off jobs.
In all cases, I think the jobs were *possible* without removing the bodies, but experience showed it was easier and quicker to do. As said, its about a dozen bolts, brake lines, some electrical connectors etc. the issue is having the lift (and roof space) to do it.
Presumably this is referring to the L320 RR Sport? IIRC these were basically an L319 (Disco 3) in a party frock and these too had a number of body off jobs. .....
I thought a Range Rover was a Ranger Rover ..... ::)
Not everything is always as it seems... ::)
The Evoke for example. :D Yeah yeah I know it's Evoque. :P ;D
Who told you that?
Range Rover ....
Not the documented method at all, just how they have chosen to do it, can't say it looks easier either (engine change time is about 7 hours using the prescribed approach)
Its a shared platform, as it is today, and as every manufacturer does. When you consider a platform costs many billions to develop its sensible.
As an example, the recent Range Rover, Range Rover Sport and Dicovery are D7u, Defender is D7x, XE, XF, F-Pace and Velar are D7a, i-Pace is D7e, there are some similarities in how it goes together, but thats it
New Range Rover and Range Rover sport is MLA (New platform).
Look at the VAG range and you will see the golf platform all over the place (MQB)
Also Mercedes MRA is common across loads of the range (and creates an issue at the bottom and top end for them as a result, hence the A class having a new platform which will move across thier lower segments)
Similarly BMW, who many say have now destroyed the 1 series by using the Mini transverse platform meaning there is no rear wheel drive 1 series available any more, only AWD with FWD for cruising.
Thanks Mark :)
I know that I never know a Range Rover from a Discovery ... :-\
