Omega Help Area => Omega General Help => Topic started by: 456lbft on 27 October 2022, 09:42:30
Title: 2.2DTi manual gearbox ratios?
Post by: 456lbft on 27 October 2022, 09:42:30
Does anyone on here know if the manual gear ratios in a 2.2DTi Diesel differ from the 2.2 Petrol manual box, or 2.5/3.0V6 etc. Officially the 3.2 only had autos behind them unless you were in uniform and driving a "special", but did they just use the same gearbox as a 2.2Petrol? I realise that because diesels don't rev, they tend to have longer final drive ratios in the diff, but wasn't sure if the ratios in the box differed too.
Thanks.
Title: Re: 2.2DTi manual gearbox ratios?
Post by: Doctor Gollum on 27 October 2022, 11:58:50
From the 2003 Edition 1 Sales Brochure...
2.2 16V (ALL)
Clutch diameter: 229mm
1st: 3.81:1
2nd: 2.11:1
3rd: 1.34:1
4th: 1.00:1
5th: 0.76:1
Rev: 3.40:1
FD: 4.22:1
2.2 DTi (ALL)
Clutch diameter: 241mm
1st: 3.81:1
2nd: 2.11:1
3rd: 1.34:1
4th: 1.00:1
5th: 0.76:1
Rev: 3.40:1
FD: 3.45:1
2.6/3.2
1st: 3.95:1
2nd: 2.19:1
3rd: 1.39:1
4th: 1.00:1
5th: 0.84:1
Rev: 3.53:1
So the only difference IS the diff. Sport and Elite models with the factory 17" wheels/tyres are a smidge slower per 1,000 rpm, but the diesel is 5 mph faster per 1,000 rpm due to the diff ratio.
The 2.6/3.2 have the 241mm clutch, but a completely different ratio set to the four cylinder cars. 2.6 manual FD is 3.90:1, 3.2 manual FD is 3.70:1.
Autos 2.2 16v/2.6 FD is 4.22:1, whereas the 3.2 FD is 3.90:1. The 2.6/3.2 share gearbox ratios.
So there's scope for increasing the top end on the V6... Scratches chin wondering where the 3.2 would get to with a 3.45:1 diff and how much difference the 3.90:1 diff would make to an 2.6 auto  :D
Post by: 456lbft on 27 October 2022, 18:14:35
2.2 16V (ALL)
1st: 3.81:1
2nd: 2.11:1
3rd: 1.34:1
4th: 1.00:1
5th: 0.76:1
Rev: 3.40:1
FD: 4.22:1
2.2 DTi (ALL)
1st: 3.81:1
2nd: 2.11:1
3rd: 1.34:1
4th: 1.00:1
5th: 0.76:1
Rev: 3.40:1
FD: 3.45:1
2.6/3.2
1st: 3.95:1
2nd: 2.19:1
3rd: 1.39:1
4th: 1.00:1
5th: 0.84:1
Rev: 3.53:1
:y From when sales brochures were written by Engineers, for men!! Thanks very much. We have squeezed a slightly bigger clutch disc onto a  billet lightweight flywheel on my 3.2 with a 2.2DTi gearbox.  I am going to go with a 3.9:1 final drive ratio for spirited driving on track...one day when it finds a home in a suitable car.  (also have some ITBs with lovely curved air horns which are said to fit under a standard bonnet, but that's even further away atm)
Post by: Doctor Gollum on 27 October 2022, 18:34:08
As an indicator, in 4th, you'll be seeing 18.8-19mph/1,000 rpm depending on tyre choice.
The factory 3.2 manual with 3.70:1 diff is a sub 8 second car with a top end of over 150mph. RWE in an estate, saloon is a smidge faster. As a benchmark, 80 mph in the same car was around 2,800 rpm (from memory).
The 3.2 manual with 3.90:1 diff is a smidge quicker off the line, but you're changing gear sooner and the top end is substantially reduced. The 2.2 ratios will exacerbate this. The lower mph/rpm will also impact economy.
I appreciate that that's not necessarily what you're building, or why, but it might matter to someone considering similar.  ;)
Post by: 456lbft on 28 October 2022, 08:32:57
Thanks for that. A friend has a factory 2.5 V6 manual (estate) and wants a taller gear for economical cruising, but the only diffs I have are 3.9:1, so no good for him, I was given a CWP from a Carlton, but I'll have to count the teeth to establish what that one actually is.  Interesting that the 2.6/3.2 manual ratios are different, do you know what the code for that gearbox might be?
I have only ever seen a couple of manual 2.6 civilian cars, the only 3.2 manuals I know of were police specials.  You are right, that is the sweet spot for a road car gearing, but there aren't many times where you'll see much over 140mph on British circuits in a Omega.  Maybe on those long straights at the Nurburgring, but maybe the rev limit could be raised for that ;). All hypothetical bench racing at the moment, but fun anyway!
Post by: Doctor Gollum on 28 October 2022, 09:51:16
A 2.2Dti diff would be a good choice if he does alot of distance motorway work...
I suspect that the 2.5/2.6 would run out of puff after 130 anyway, but it might get alot nearer 40mpg on a steady cruise.
Cruise control is a pretty easy retrofit on any Omega if it doesn't already have it.  :y
There was a 3.2CDX manual estate of reportedly Royal provenance on Ebay a few years ago, but the 3.2 manuals were a factory option via special order. That's to say nothing particularly special about them beyond the fact that they were built to order.
You or I could have walked into the dealer and ordered one after a bit of a debate... Retail price of a 2003 V6 Special, 3.2 manual with xenon, self levelling and 16"wheels was £18,500.
Post by: jb on 31 October 2022, 19:36:12
The  2.5 v6 and 2.6 v6 manuals had an R25 GETRAG box, the 3.0 an R28 and the 3.2 special an R30 box. The R value being safe max torque.
Post by: Doctor Gollum on 31 October 2022, 21:04:25
True, but the ratios are as above ;) difference being a hardened gear set.
Post by: 456lbft on 05 November 2022, 10:29:47
I assumed that the 2.2DTi had the hardened gears to cope with the torque of the diesel, so presumably are the R30.
Post by: Doctor Gollum on 05 November 2022, 10:42:51
Possibly R28, but it will be cast on the casing, so no ambiguity ;)
Post by: VXL V6 on 05 November 2022, 21:33:19
The casting in the casing of the box on my old DTi said 'R25 R28' But then I guess the casing will be the same and there is a plate attached somewhere that tells you what's inside.
(https://i.ibb.co/KmQcpfj/17032012456.jpg)
Post by: Doctor Gollum on 05 November 2022, 23:23:47
Presumably said plate is a code on the build sheet.  :-\
Post by: omegod on 09 November 2022, 15:31:41
From what I was able to decipher after some research many years ago all the boxes marked R25-28 are identical, the near mythical R28 has shot peened internals so it could take more of a battering. I sold scores of the R25-28 gearbox kits to kit car builders and the like who were putting 350-400 bhp through them and I've never had any feedback regarding problems or request for replacements..... they really are a tough box !
