Chat Area => General Car Chat => Topic started by: Viral_Jim on 07 November 2022, 21:11:21
As per the title, the big bushes with the oddly shaped lobe on them (oo err ::)). Are they hard to change and are any special tools required to wind the new ones in?
I watched a YT video of a guy doing a set, but he made such an ar$e of it I couldn't work out if it was difficult or not ;D.
No doubt Dangerous Dave has done a few hundred, likewise that DTM bloke has probably done a few, so I thought I'd ask those what know...
I use the usually trick of hacksawing through the outer bush after knocking the centre out and then fit a powerflex or Polish equivalent.
To get to them though you do need to remove the fixing bolts as the bush bolt cannot be withdrawn otherwise (hits the sill), once done it hangs happily on the shocks and you can jack at the rear of the spring cup to gte the front of the trailing arm to lower for access
Thanks very much! Tbh I didn't realise that poly bushes were available for this application. Should make the whole job much easier!
