Chat Area => General Car Chat => Topic started by: STEMO on 10 January 2023, 15:17:02
Smallish leak around the bottom of the radiator somewhere. Thought I might take it to the car doctor for a bit of TLC, but decided to give it a bottle of redweld medicine to see if it got better. We'll see ;D
OMG you can't admit to doing things like that on here! :o
I've been using it since before most of the pups on here could drive. Does the trick with small leaks.
yes radweld and barrs etc work fine .especially if you only use a small amount.
i always add a half bottle when doing a flush and refil to all my cars . heaters all still work fine. ( obviously excessive amounts will settle and clog a matrix but quarter ir half bottle dont !
Whole bottle went in mine. It was raining, you know ;D
itl be fine !
i once had a xj6 that sprang a rather large leak from thefront somewhere .(big pool under after shopping trip). put a bottle of barrs in and filled it back up. it never leaked again and was fine 2 years later when i sold it
itl be fine !
I've always used the whole bottle, because it says use the whole bottle ;D
In that case I'm surprised that you didn't crack couple of eggs in there if you're that old skool! ;D
Done that before, once. It didn't work.
Did you have a nice breakfast though? :)
No, Ron, you don't put them in with the shells on. ;D
Did you use free range or battery hens eggs? ??? :)
Proper, fossil fuel hens, not poxy electric ones. ;D
Silly clucker. :P
So no sheep poo then? Told by a few folks it works.
No more leaky :y
No more leaky :y
My L322 Range Rover has used a pint of coolant a month, consistently, for the 4 years I've had it. Never got better, or worse. I can't see any leak, it's so slow. Runs like a dream, never overheats.
I've just topped it up every month when it gets low. And I'll continue doing so, until the leak becomes more obvious and identifies itself :-X
Being a BMW, it will be something plastic and forty zillion quid to replace :D
